BigJimnyMeet 2024
springs with dislocating cones
- Thank you received: 16
10 Jun 2020 18:05 #223459
by safari
if u worry u die if u dont worry u still die so why worry
springs with dislocating cones was created by safari
hi everybody has any one here made springs with dislocating cones for extra articulation .would love to do them on my jimny but confused on shocks length and other parts
- Thank you received: 923
10 Jun 2020 20:59 #223468
Replied by X8GGY on topic springs with dislocating cones
No eBay APP ID and/or Cert ID defined in Kunena configurationNoticed these on eBay...
- Thank you received: 1761
11 Jun 2020 05:58 #223471
Replied by Lambert on topic springs with dislocating cones
I'm not entirely sure what the benefit is supposed to be in having springs be able to dislocate. It makes the wheel remain in contact with the ground longer but there is so little pressure applied to that tyre that it's effective traction is is minimal which with an open diff means wheel spin and with a locking diff it makes no difference if the wheel is kinda touching the ground or is 2 feet in the air drive will still go equally to the other side of the axle. As for stability if there is an air gap between the spring and the chassis or the wheel and the ground it is still a gap that is unsupported.
- Thank you received: 168
11 Jun 2020 11:18 #223479
by 300bhpton
Replied by 300bhpton on topic springs with dislocating cones
Personally I'm not the biggest fan of dislocating setups. But is there really significantly less pressure on the wheel than a non dislocating setup?
Surely if your retained spring is fully extended, then it too is only the weight of the unsrpung mass pulling it down. As the vehicle weight clearly isn't on that wheel, else the spring would be compressed.
If articulation across the axle is occurring, a retained spring that is too short may actually be pulling up, rather than pushing down as the spring is stretched. Which I'd have thought would give less ground pressure than the same wheel but with a dislocated spring.
- Thank you received: 552
11 Jun 2020 13:15 - 11 Jun 2020 13:15 #223488
by Scimike
Replied by Scimike on topic springs with dislocating cones
Just thinking about it. Some of the load from the compressed side will be transferred through the solid axle due to the leverage against the compressed wheel, so it's possible more load is present on the decoupled side than just the unsprung mass?
So it may offer more traction.
Complications due to the solid coupling of both wheels
Still not answered Safaris question - anyone got any suggestions about shock length?
Last edit: 11 Jun 2020 13:15 by Scimike.
11 Jun 2020 13:34 #223489
by safari
Replied by safari on topic springs with dislocating cones
Tks everyone for the feedback
Basically I am willing to make dislocated cones because our offroad is mainly on articulation therefore crossaxel since it is offroad on rocks
Jimny is very capable compered to land rover but a land rover with dislocated cones in this terrain have a plus on me sometime you just need that little bit more traction to get out of a situation
11 Jun 2020 13:39 #223491
by safari
11 Jun 2020 16:16 #223499
Replied by Riccy on topic springs with dislocating cones
The radius arm bushings will bind up before the spring runs out of travel and dislocates, unless your changing them to johnny joints, or going 3-link with it all.
Then you would need to increase shock travel significantly too. I would say the dislocation kit is pointless on a fairly normal jimny. Lockers would be a better investment
11 Jun 2020 18:21 #223506
by Busta
Replied by Busta on topic springs with dislocating cones
Wouldn't replacing the bushes with Johnny joints not just make the whole axle bind up? I thought it's the big squishy rubber bushes that allow it to flex in the first place.
11 Jun 2020 18:55 #223507
by 300bhpton
In terms of shock length. I’d have thought as long as possible. The limitations are the closed length. You will still want the axle to uptravel/compress without bottoming the shock out.
On a Land Rover you would move the upper shock mount to allow for a much longer shock. Thus retain the compression with much more droop. I assume something similar can be done on a Jimny.
- Thank you received: 225
12 Jun 2020 02:13 - 12 Jun 2020 02:20 #223519
by zukebob
Replied by zukebob on topic springs with dislocating cones
Safari:
Trying to back this up to the original question, are you currently having an issue with your springs dislocating?
If not, are you considering a suspension mod that might cause spring dislocation?
Last edit: 12 Jun 2020 02:20 by zukebob.
12 Jun 2020 08:34 #223522
by kirkynut
Replied by kirkynut on topic springs with dislocating cones
Save up for a locker. Much more effective.
The following user(s) said Thank You: lookonimages
Time to create page: 0.188 seconds
