BigJimnyMeet 2024
'05 Corrosion advice Most appreciated....
- TillymintDLG
- Visitor
27 Apr 2020 07:59 #221557
by TillymintDLG
Replied by TillymintDLG on topic '05 Corrosion advice Most appreciated....
Hi Facade, I missed that one! Just been having a mooch again and like the look of this one... www.machinemart.co.uk/p/clarke-at133-arc...mma-inverter-welder/ at that price + the Tig option, I think it's worth a try!
Talking about Aldi, I did get their Auto Darkening mask (£23) one of the best buys I've ever made, to be able to stick weld with both hands is a revolution IMO.
Gaz
Gaz
- Thank you received: 47
27 Apr 2020 19:06 #221573
by Jimny Dr
Replied by Jimny Dr on topic '05 Corrosion advice Most appreciated....
Hi tillymint
Looking at your pictures they all end up needing the same amount of welding in the same areas, don’t waste money on a new front panel just for the bits that the picture shows. I’ve done quite a few now and buying a front panel not give you the front inner wing sections that you needs.
Cut out the rot and rebuilt with new metal providing the chassis mounting section is still good which they normally are.
then seal up with good primer
The doc
The doc
The following user(s) said Thank You: TillymintDLG
- TillymintDLG
- Visitor
28 Apr 2020 00:36 #221577
by TillymintDLG
Thank you very much for your reply And pics Doc!
The info I am getting from this Great forum is such a big help!
As mine is my only daily driver plus not being able to access my drive at the mo, I can't strip it down to the level that you have (and others) have shown..My local garage, who I have been going to for about 20+ yrs now, very good and they have experienced welders too! Compared with what I have seen here, my '05 seems to have had an easy life re the Jimny rust bug. It's MOT'd till Nov this year and have been waiting for the weather to improve so that I can get underneath and have a good look round..My garage has had a look underneath when I had the flashing 4WD light issue and found a pipe hanging off one of the hubs, and didn't flag anything else (Yes, I trust these guys) I will take off the plastic mudflaps and headlights to get a better idea of what needs to be done...
I am now thinking about stabilising the existing rust as it is now because I am desperate to get out camping with my doggy this year (subject to this scamdemic)..
Thanks to all for your help!
Regards
Gaz & Tilly (SWMBO)
Regards
Gaz & Tilly (SWMBO)
- Thank you received: 583
28 Apr 2020 10:18 #221590
by facade
Replied by facade on topic '05 Corrosion advice Most appreciated....
Have a look around youtube and forums for mig & tig welding. (e.g. www.mig-welding.co.uk/) If you are going to do your own body repairs it always used to be a mig welder that was more use. I don't think you'd get good results trying to weld rust repairs with a £200 tig welder, but things move on rapidly.
I've got one of the clarke gas/gasless welders a 151EN, you have to switch polarity for gasless wire- and it makes a hell of a mess compared to using gas (but they work in a breeze like a stick welder). I don't know why the 151EN is cheaper than the red ones, but it does look like it was made in 1975. It is supposed to wire to a 30 outlet, but mine came with a 13A plug in The Olden Days, and I've not blown a fuse yet.
- Thank you received: 1759
28 Apr 2020 12:20 #221594
Replied by Lambert on topic '05 Corrosion advice Most appreciated....
The last lot of rust repair I did on the farm was with my sip 174 stick welder with some fairly small rods. With practice it's quite possible to weld thin sections like used oil barrels to a water tight standard. It all depends on how much practice you have.
- TillymintDLG
- Visitor
28 Apr 2020 14:25 #221601
by TillymintDLG
And that's exactly what I'm lacking Lambert! Practice....
28 Apr 2020 16:36 #221609
There are many tutorials on the internet that will get you going and with time and some scraps of steel you will get better.
01 May 2020 08:36 #221724
by HUN
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
Replied by HUN on topic '05 Corrosion advice Most appreciated....
TillymintDLG
An often overlooked spot for rust is the rear upper spring seat. Especially inside the rubber cone! Spring seat mount has a hole on the top which collects water. This hole drains the water directly into the rubber cone which traps the water and keeps the mount internally wet even in dry wheater! When this small bit of metal whithin the rubber is gone the spring will dislocate. Try to avoid this obviously. Just because you cannot see any rust outside it does not mean there it's no heavy rust inside the rubber cones!
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
- TillymintDLG
- Visitor
01 May 2020 09:11 #221726
by TillymintDLG
- Thank you received: 651
01 May 2020 09:34 #221728
Replied by jackonlyjack on topic '05 Corrosion advice Most appreciated....
The rear rubber cones
I popped a hole in the point,so it can't collect water
- TillymintDLG
- Visitor
01 May 2020 11:03 #221732
by TillymintDLG
Good idea Jack! Maybe it doesn't rain in Japan?
Gaz
Gaz
01 May 2020 18:16 #221748
by HUN
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Hi Gaz, yes No.4 is the one I meant. Whilst I was trying to pull and turn to remove the cone it produced a wierd sound like smashing bread crumbs Then the tip of the cone fall down and a good amount of rust mixed with dirt poured out through the hole. My Jimny is also 05 reg so there is chance for this on yours as well.
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Time to create page: 0.169 seconds
