Gen.4 Jacking Advice
- Thank you received: 1759
- Thank you received: 584
DAGZOOK wrote: For all those interested - or those that may be in a similar predicament, I've settled on the following bit of kit. This will allow you to lift the front or rear of the vehicle quickly and safely to a height of around 650mm. Enough even for high reach axle stands! the kit costs £140 - but is guaranteed for years and will enable easy servicing/annual cleaning. Pretty space efficient too..
www.sgs-engineering.com/tj3b-3-ton-troll...ack-and-jacking-beam
Crikey!!!
Get some stands solid underneath the chassis before you go under that
- Bill Portland
- Thank you received: 77
Have you got axle stands already?
- Thank you received: 96
Should have been more explicit, I've already got axle stands and fully intend to use them chaps. I've also got a set of ramps which I use for general servicing. My driveway is probably about as flat as they come.
The whole reason for wanting the beam is because I'm strongly against jacking from the Diff housing not so much because it's not strong enough, but because it's so easy for the car to tip/fall. Yes the JIM may have to be driven up onto some blocks in order to use the beam - not a big deal. Still far safer than jacking each corner up onto a high stand.
My existing low profile trolley jack is great for the sports car and the odd hatchback, but it won't touch the Jimny unless you use several blocks. I've tried it and it feels unstable with the amount of suspension flex the Jimny has got, the block could slip out.
For my Diff breather install I used the factory scissor jack. I was there for most of the afternoon
Happy to take on suggestions if you guys could show me what gear you use? Like I said this is the first 4x4 I've owned, never had this issue before. It's usually the opposite!! (no ground clearance)
If I'm lifting the whole front or rear end I go under the diff housing. There is no problem with tipping because the other axle is either still on the ground or resting on 2 axle stands.
Any recommendations on a Jack? a friend of mine recommended this one as SGS seem to have mixed reviews online. I know that 3 tonne is overkill for the Jim, but it's more about max height, my stands extend to a maximum of 500mm. That sort of clearance would come in handy when giving the underside a power wash
www.amazon.co.uk/Sealey-3040AG-3tonne-Tr..._details?ie=UTF8&me=
