Gen4 Jimny Service manual
- warrengti
- Visitor
or wiring diagram ?
I am looking for Acc trigger wire and Illumination wire
Thanks
- Thank you received: 34
- Thank you received: 479
They are Toyota short switches. Should be able to find them closer to you than Australia where I got mine.Soeley wrote: Hi Crash, where did you get the switch from? I managed to get THIS ONE it blue illumination, I have been meaning to take it apart and see if I can swap it to amber LED to match OEM.
You choose a base and a cap to suit what you like.
qled.com.au/index.php?route=common/home.
crash486
crash486
Thanks, I'll look into it.
- warrengti
- Visitor
I do like the look of those switches that will be a mod im going to do later im looking at an AFN loopless bar and I would put 2 x 7" led spots on the front.
Off topoic I guess but back to it after a scuseesful day of installing dynomat in the doors and body and upgradeing the speakers while I was in there. I used the pioneer 5.25" 3 way speakers unfornatley thse were not a direct swap like the 2 ways but not so bad to install bit of custom work with some MDF and waterproofing.
Tomorrow I any doing to try and install my under seat sub and my narva 12 was fused distrbution block this has 6 x power feeds and 6 x acc feeds and 12 earths. this is why I was looking for the ACC feed Anyway i will get the meter out tomorrow and check out what is under there. Might take photos of this one could be handy for people wanting to install a 2way or somthing after market that requires power.
- warrengti
- Visitor
Had to make a small stell braket to mount it to
It sits just above the drivers fot well trip and is hidden nicely despite the size
- Jazza
- Visitor
Trying to wire up a spot light switch right next to my other OEM switches, didn't wont to have to buy a power probe if I didn't have to!
Cheers
- Jazza
- Visitor
- Thank you received: 77
- Jazza
- Visitor
