BigJimnyMeet 2024
Re:G13BB Engine runs rough intermittent
- Owl
- Visitor
24 Mar 2020 02:39 #220203
by Owl
Replied by Owl on topic Re:G13BB Engine runs rough intermittent
Had CAT converter checked and it is OK to go. Found the back end fuel rail bolt was slightly loose leaking a small amount fuel, have tightened and sealed that. Thought that was the problem but it wasn't.
The symptoms persist, more so when the engine gets to operating temp, its affecting the idle , the idle fluctuates from approx. 800-850 rpm to 1000, up and down, erratic, it did stall once at idle. Today it drives ok but the idle was more the problem. Its erratic, it can occasionally feel like a misfire, sometimes a little surge but not consistent. Its strange.
- Thank you received: 1755
24 Mar 2020 05:24 #220205
Replied by Lambert on topic Re:G13BB Engine runs rough intermittent
Then Martin's assessment of a sensor being bad is correct.
24 Mar 2020 08:36 #220207
Replied by mlines on topic Re:G13BB Engine runs rough intermittent
Idle going up and down can be a split hose in the intake/emissions system.
A test for this is to carefully (its explosively flammable) squirt "Easy-start" around the pipes. If the revs rise then you have found the hose thats leaking.
- CC Baxter
- Visitor
24 Mar 2020 10:05 #220211
by CC Baxter
Replied by CC Baxter on topic Re:G13BB Engine runs rough intermittent
Excellent! Old fashioned, easy route mechanics. I doubt they still teach this stuff which partly explains high labour charges. Chris
- Owl
- Visitor
25 Mar 2020 08:05 #220244
by Owl
Gday Martin and All , Ive pulled the cam sensor out and it is wet with oil. Is it supposed to be in contact with the engine oil? Owl
- Owl
- Visitor
25 Mar 2020 08:08 #220245
by Owl
Yes did that with some carb clean spray and nothing definite came of it. I thought for a minute when I sprayed the fuel regulator the engine stumbled but later it didn't show symptoms. The carb spray cooled the area down for a short time.
- Owl
- Visitor
27 Mar 2020 07:22 #220304
by Owl
Got a diagnosis for the problem, IAC Valve fault, open circuit, part no: 18137-64G01
- Owl
- Visitor
05 Apr 2020 00:48 #220707
by Owl
Hello All, Got the engine repair done, it was the IAC valve sometimes known as ISC solenoid on other vehicles, very expensive part so I sourced a very expensive non gen part but still a couple hundred less than gen part. The idle and performance is stable and smoother. Thanks to all for advice, Martin picked it as a likely sensor issue. thanks Owl.
