BigJimnyMeet 2024
Re:Re:Re:Oil in spark plug tube.
18 Dec 2019 18:00 #216567
Replied by Riccy on topic Re:Re:Re:Oil in spark plug tube.
Sorry, im thinking of the gasket I pictured and mixing it up as the rocker gasket, rather than the spark plug ones
- Thank you received: 2
18 Dec 2019 18:14 - 18 Dec 2019 18:15 #216569
by Wailin
Replied by Wailin on topic Re:Re:Re:Oil in spark plug tube.
No it wasn't me enquiring about the m16 vvt!
So just to be clear, in the liana 1.6 (2004) engine, the spark plug gasket and rocker cover gasket are the one unit? So I'll need to replace the rocker gasket and the 4 sparkplug o rings in one go? The problem for me is I bought the jimny with the liana engine fitted so I have no engine code and can't nail down the exact part number. Some sites show the o rings separate to the rocker gasket while others gave them integral.
Last edit: 18 Dec 2019 18:15 by Wailin.
18 Dec 2019 18:22 - 18 Dec 2019 18:24 #216570
Replied by mlines on topic Re:Re:Re:Oil in spark plug tube.
As Ricci says the 1.6 Liana takes the sparkplug standard gasket, like the M13, which is in stock here
www.bigjimny.com/store/spark-plug-gasket/seal.html
Ignore out conversation about the M16 VVT Swift Sport which is a different gasket and was only introduced into the conversation as someone messaged me the exact question about the engine at the same time as you
Last edit: 18 Dec 2019 18:24 by mlines.
19 Dec 2019 06:20 #216574
by Wailin
Thanks Martin, I've ordered the gasket. Since I'm removing the head cover to replace the gasket it might be a good idea to change the rocker gasket too. Would you stock those for the M16a engine?
Time to create page: 0.144 seconds
