- Forum
- Suzuki Jimny
- Jimny Technical
- Gen 4 SZ5 Alloy wheels and 215/75/15 Toya Tyres - Balancing proving challenging
www.dynabeads.co.uk/
Ive just bought some ceramic ones from them to try after mixed results with the plastic ones from devon4x4
- Visitor
- Thank you received: 332
I added a thicker shim to the lower kingpin and that improved the wobbling about 50% so that might be the issue, I have not done the complete king pin service yet.
Friend of mine balanced the wheels with the cone to perfection acc to the machine...
Maybe I could mount the wheels on a machined spacer with bolts next time to see if there is a difference.. The wheel will be centered on the spacers machined center hole.
- Max Headroom
- Banned
- Thank you received: 217
Daniel30 wrote: Does the prewar car have inner tubes?
Yes it does.
I've heard of people using beads on very old cars with tubes before, but never actually met anyone using them... I therefore thought it might be a form of snake-oil
- Visitor
- Max Headroom
- Banned
Daniel30 wrote: I bet it is a pain getting them balanced
I have Blockley Tyres just up the road from me - they specialise in classic and vintage car tyres and supplied both the wheels (which came from MWS ) and my tyres for the car, they can balance them so theres no big issue actually getting them balanced, but its further periodic costs and maintenance, so I'm now interested in the beads and how good they actually are.
As with all these things I find it better to speak to people actually using the product rather than someone trying to sell it, therefore getting first hand experiance from an independant non biased source
Max Headroom wrote: Kirkynut
sorry to hijack this thread momentarily, I may have asked this before (sorry grey cells are not what they were) have you had any issues with the balancing-beads at low speeds?
...or put another way, at what speed do they become effective? Or is it something that you don't really notice?
I'm considering balancing beads in my prewar car( lumps of weights added to wire wheels just looks very ugly)
No issues at all. Fit and forget.
I usually have a spare bag in case I get a puncture and the beads get lost during the repair or tyre change though.
They work by the time the car is at any speed where balancing is an issue as centrifugal force sorts them out to be in the right place. Given an inner tube presses up against the inside of the tyre I cannot think of a reason not to use them if you can get them through the valve but the ones from Devon 4x4 are too big to fit through the valve hole.
- Max Headroom
- Banned
Well... I went ahead and bought some from Dynabeads UK - not for the pre-war car but the Jimny (the pre-war motor is way off being driven yet)
The 4x4 beads are bigger and, as you say, won't go down the valve stem so I've elected to use the smaller beads, the only difference being... they're smaller - probably easier to lose when the tyre gets changed though.
All the reviews I've read anywhere, are really very good.
I will get round to putting them in the vintage tyres once I've convinced myself
- Thank you received: 583
If I remember, I'll have a look at my New Motorcycle, it has wires, and I don't recall noticing any balance weights, but the rims are made from "corrodamatic" alloy so they could just be stick-ons that I haven't looked for.
- Thank you received: 34
tundraheadquarters.com/bead-balancing-tires/
- Forum
- Suzuki Jimny
- Jimny Technical
