Cable entry from engine to cabin ?
- Blackout
- Visitor
- Thank you received: 1759
- Blackout
- Visitor
- Thank you received: 651
After that i drilled a hole and used a cable gland
- Blackout
- Visitor
use a paper clip but first make it flat using a hammer then push it down from the front and pull steady on the wires
- Thank you received: 475
Soeley wrote: When I fitted a temp gauge to my last car I had to get the sensor end through a similar grommet. So I used a sealant nozzle and some WD40, it went in like a hot knife through butter.
That's clever. I'm stealing this idea for the future.
- Blackout
- Visitor
- Podge
- Visitor
You can push it through from the engine bay but my grommet had a tape seal on the inside which wouldn't let the grommet stretch and the cable been pushed through. Once it was off it was easy to push the cable through .
Blackout wrote: That’s a great idea! Did you have to cut the grommet? I have fear of nicking one of the wires as I cut, guess I could pull it back a bit
I just punched through first with a small electricians screwdriver.
