BigJimnyMeet 2024
3rd Gen Suzuki Jimny VVT 2005 M13A - R72 Gearbox Refurbishment
- Thank you received: 45
13 May 2019 06:53 #207839
by HUN
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
Hello All,
I've started populating some detailed (I mean very detailed) photos of the refurbishment of my spare R72 gearbox. I'm unsure if this Google sharing works or not. Please give it a try.
photos.app.goo.gl/2ftXQnt51fCvHoL59
Regards,
Gabor Stotzer
Regards,
Gabor Stotzer
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
- florinelu07
- Visitor
13 May 2019 07:26 #207843
by florinelu07
Replied by florinelu07 on topic 3rd Gen Suzuki Jimny VVT 2005 M13A - R72 Gearbox Refurbishment
Impressive!
- Thank you received: 1759
13 May 2019 07:42 #207846
Replied by Lambert on topic 3rd Gen Suzuki Jimny VVT 2005 M13A - R72 Gearbox Refurbishment
Thank you for sharing!
- Max Headroom
- Banned
- Thank you received: 217
22 May 2019 15:23 #208685
by Max Headroom
Replied by Max Headroom on topic 3rd Gen Suzuki Jimny VVT 2005 M13A - R72 Gearbox Refurbishment
SUPERB!
Thank you!
Thank you!
26 May 2019 21:27 - 26 May 2019 21:27 #209041
by HUN
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Replied by HUN on topic 3rd Gen Suzuki Jimny VVT 2005 M13A - R72 Gearbox Refurbishment
Thanks Guys.
Well, I've just finished the disassembly of the R72 gearbox today. I don't have too much time to work on this, but who has nowadays? Anyway.... at this moment it's alteady documented with 200 photos...
I think it's so detailed that it can be used by anyone without any explanation (you just need to feel confident to open the gearbox housing). Photos are self explanatory. Might be useful for those who does not speak English as there is nothing to read there! Ha-ha.
Now I had to realize that I have not ordered everything yet for this rebuild. Synchro sleevies needs to be ordered before I can carry on with this. Once I got them another few hundred photos will follow showing the assembly.
I hope it helps keeping your pride and joy on the road whilst you might learn something new like I did!
Enjoy.
Enjoy.
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Last edit: 26 May 2019 21:27 by HUN.
26 Sep 2019 19:53 #213890
by HUN
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Hi guys.
After a month of waiting for parts I've nearly finished my gearbox rebuild last weekend. Unfortunately, I could not put back the rear section (3rd smallest part of the housing) of my R72 gearbox because the counter shaft bearing and the output shaft bearing do not line up perfectly. Possibly it's a very tight and precise fit. Managed to get those bearings half way pushed into place by pushing the housing down but then it does not go further. Does anyone had similar problem during assembly? Shall I try to heat up the 3rd piece before I give it a go? It's a real pain in the bottom especially because once the sealant is applied then there isn't too much time for messing with housing. Thanks. .
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
- Dano0404
- Visitor
27 Sep 2019 07:18 #213912
by Dano0404
Replied by Dano0404 on topic 3rd Gen Suzuki Jimny VVT 2005 M13A - R72 Gearbox Refurbishment
I don't remember having any trouble on mine with this. How ever that is a sealed bearing and I belive there is a seal on the output shaft so it could be trapped air? We have this problem at work with a lip seal against a sealed bearing, you can ease a small screw driver under to realise the pressure. It should be a tap fit a gentle tap.
Heating up can be a good idea but you have limited time to work with it. Also the risk of it going cold and not being where you want it.
Good luck
Good luck
27 Sep 2019 20:38 #213947
by HUN
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Dano0404
Ahaa! So that's why it bounces back! I found this bouncing issue with the counter shaft bearing only which sits into the housing without let the air escape. I just have not realized that this is the source of problem. I'll give it a go then! Thanks for pointing me to right direction!
G.
G.
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
28 Sep 2019 12:07 - 28 Sep 2019 18:06 #213969
by HUN
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Last edit: 28 Sep 2019 18:06 by HUN.
- Visitor
28 Sep 2019 21:57 #213982
Replied by Daniel30 on topic 3rd Gen Suzuki Jimny VVT 2005 M13A - R72 Gearbox Refurbishment
Good news well done
29 Sep 2019 11:13 #213995
by HUN
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Thanks Danny
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
- Dano0404
- Visitor
29 Sep 2019 16:38 #214017
by Dano0404
Top work. Before I took mine apart it had a rattle in 3rd even though all the bearings felt good after I put it back together all was sorted. Have you tried running through the gears before putting it back in? I got something backwards in mine on my first attempt and could select all of them.
Time to create page: 0.168 seconds
