Temporary/timed warning lights on dashboard
- Keirravn
- Visitor
In the process of fault finding behind the dash I've managed to knock out some of my warning lights. I believe I shorted them out. Engine management and oil are the obvious ones that aren't working. It's not the bulbs. Battery light and abs light still works.
Is there a relay somewhere that controls the lights that come on for a few seconds? Is it built in to the circuitry of the instrument panel?
Help appreciated
- Keirravn
- Visitor
Dash fuses fine. Wouldn't have thought the fuses by the batter would impact it but I'll check to be sureRiccy wrote: Checked all the fuses? some under the dash and some near the battery
- Keirravn
- Visitor
J999pre will probably have a spare dash cluster to swap in. Mileage displayed will correspond to the used part there, but it should work.
- Keirravn
- Visitor
So do you reckon the instrument panel has internal resistors or some such which controls the temporary light up as opposed to it being a separate part or from the ECU?Riccy wrote: sorry for the obvious question, but it had to be asked. Check earthing and connections, otherwise its a spare part needed.
have you had a code reader on to see if that works?
- Keirravn
- Visitor
Ah great that would be a handy easy fix then. Just a shame to lose my 66k on the clockRiccy wrote: Yes it has a PCB sort of arrangement and has IC's and processors, so easily damaged part. Like i say, the mileage is stored in the dash cluster somehow, therefore it must be more than just lights and wires to them. I doubt the ECU would be damaged or the car would have bigger issues.
I do but there's no faults showing. MOT is out I was planning to put it in to the garage tomorrow. Typical really
I'm not sure but the ecu might store the mileage. So a replacement might show your car's mileage.
- Thank you received: 332
kirkynut wrote: I'm not sure but the ecu might store the mileage. So a replacement might show your car's mileage.
Nope, my mileage (km) was very much improved after changing the cluster.
Pictures: www.bigjimny.com/index.php/forum/8-my-ji...kuza?start=84#203590
might be different on older cars though, mine is a 2005. the cluster is 2012.
Could be there is also a milage read out from the ECU that shows the real mileage, but that does not update the cluster mileage.
Brake warning light did not shut down before, and after changing the cluster more lights will shine for a test first few seconds after turning ignition on. Can hear relays clicking on - off corresponding to the warning lights as well now.
- Keirravn
- Visitor
I can live without a management light but the oil light is also missing which is the potentially worrying and expensive issue ...
It is all there in the FSM, but the wiring inside the cluster is more difficult to find.
