BigJimnyMeet 2024
Gen 4 Front Grille Removal
- Roger Fairclough
- Thank you received: 193
05 Nov 2020 08:55 #229697
by Roger Fairclough
Replied by Roger Fairclough on topic Gen 4 Front Grille Removal
Start at a corner and pull hard. Yes it will probably make some noises but if you want the grill off you must persevere. I will assume you have released the clips that you use a small screwdriver to lever the screw out!
Roger
Roger
- Matt5141
- Visitor
05 Nov 2020 09:16 #229699
by Matt5141
Replied by Matt5141 on topic Gen 4 Front Grille Removal
I have released the clips under the bonnet and the 90° ones at the bottom of the grille, shown in the pictures in the previous replies. Trim clips were mentioned as well but couldn't figure out how to get to/remove these. Do these also need doing before pulling?
- lookonimages
- Thank you received: 64
05 Nov 2020 10:28 - 05 Nov 2020 10:30 #229700
by lookonimages
Replied by lookonimages on topic Re:Gen 4 Front Grille Removal
After 90 clips and 2 under bonnet you just have to pull. Start at lower corner and pull towards you. The clips will release itself. Work al round till you get to bottom again.
Found that starting at bottom where 90 degree clips are you have more of a hand hold there.
Last edit: 05 Nov 2020 10:30 by lookonimages.
The following user(s) said Thank You: Matt5141
- Thank you received: 34
06 Nov 2020 21:08 #229757
by crash486
Replied by crash486 on topic Gen 4 Front Grille Removal
Lower black clips rotate through 90 deg, upper push clips, then the very tough white clips. I started at the top near the headlight. Yes , I thought I'd break the grill but I didn't. Good luck.
- Matt5141
- Visitor
06 Nov 2020 21:25 #229758
by Matt5141
Where are the white clips?
26 May 2021 07:03 #235375
by 1tamad
Replied by 1tamad on topic Gen 4 Front Grille Removal
HELP! I'm stuck with the top of the grill. The grill is held fast by something on top of the 'S' in the middle and won't budge. I'm afraid to break it.
- Thank you received: 468
26 May 2021 08:49 #235380
Replied by Soeley on topic Gen 4 Front Grille Removal
Have you removed the 2 plastic push rivets that go to the top of the radiator housing?
26 May 2021 08:53 #235381
- Axholme Lion
- Premium Member
- Thank you received: 10
26 May 2021 09:58 #235385
by Axholme Lion
Replied by Axholme Lion on topic Gen 4 Front Grille Removal
I was thinking about upgrading the horns to something louder than you'd expect on Noddy's car. Has anyone any recommendations for any louder horns on the Gen 4 which will plug straight in without any messing around?
- Roger Fairclough
26 May 2021 10:18 #235388
by Roger Fairclough
There is just enough room to mount the horns in front of the blanking plate adjacent to the off-side headlamp but the pump needs to go inside the engine bay alongside the rad. on the off-side. The standard wiring is not up to the load of the pump so you need to fit a 30 amp relay, activated by the standard horn wiring and feed directly from the battery.
Soeley's picture appears to show a different horn to my original unit so maybe he has a different solution.
Roger
Roger
26 May 2021 13:25 #235400
Yes, that is a Stebel Naughtilus I already had. I had to split the trumpet from the compressor though to fit it there.
