BigJimnyMeet 2024
Gen 4 Front Grille Removal
- Thank you received: 468
22 Feb 2019 15:07 #203682
Gen 4 Front Grille Removal was created by Soeley
Does anyone know how to remove the front grille? Found a few catches and fasteners but it's still held tight.
22 Feb 2019 16:32 - 22 Feb 2019 18:53 #203691
Replied by Soeley on topic Gen 4 Front Grille Removal
Easy when you know how!
From under the bonnet remove two plastic push rivets. Then at the bottom of the grille in the lower horizontal slot release two clips. Once those are done there is just a series of trim clips around the indicator area and along the top edge. Just pull firmly.
A big thank you to Darren at KAP for letting me disturb him while he was in the spray booth
NOTE: Photobucket back up so pictures added.
Last edit: 22 Feb 2019 18:53 by Soeley.
- Thank you received: 923
22 Feb 2019 17:07 #203693
Replied by X8GGY on topic Gen 4 Front Grille Removal
You can't tease us with half a story?!
WHY are you taking the grill out? (on a brand new car?!)
22 Feb 2019 19:07 #203700
I'm replacing the horn.
I have a Stebel Nautilus compact Air Horn. I had it fitted to my previous car ans it has to go on the Jimny. I was hoping it would fit where the std horn is, but it's a bit tight, but I have a plan
- Thank you received: 1754
22 Feb 2019 19:50 #203702
Replied by Lambert on topic Gen 4 Front Grille Removal
Swapping it for a train horn?
22 Feb 2019 20:07 #203704
Haha, not quite but nearly.
01 Feb 2020 12:43 - 01 Feb 2020 12:48 #217923
by 1tamad
Replied by 1tamad on topic Gen 4 Front Grille Removal
Do you have better pictures on the location of the push rivets and lower clips?
Where do I start to pry the grill off. I'm afraid to break it.
Thanks.
Thanks.
Last edit: 01 Feb 2020 12:48 by 1tamad.
01 Feb 2020 17:03 #217931
Photobucket is rubbish for blurring out pictures now I have reached my limit Here they are hosted by Imagur.
01 Feb 2020 18:38 #217936
by 1tamad
Thank you very much.
01 Feb 2020 18:47 #217937
I should have added. with the bottom clips just insert a screwdriver and turn 90 degrees, the bottom of the grille will pull away. When refitting and it is pushed into place turn 90 degrees again to lock into place.
- Grim Reaper
- Senior Member
- Thank you received: 10
07 Jul 2020 10:10 #224636
by Grim Reaper
Replied by Grim Reaper on topic Gen 4 Front Grille Removal
The part number for the bottom clips is 72115-78R00
For when you break them because you didn't know they were quarter turn and you couldn't work out how they released
- Matt5141
- Visitor
05 Nov 2020 08:37 #229696
by Matt5141
Replied by Matt5141 on topic Gen 4 Front Grille Removal
I've undone the push rivets and lower slot release but struggling from there. Do I need to undo all the trim clips before pulling the grille off as I can't really get to them and feel like ill break the grille if I pull beforehand
