radiator removal
- littletriple
- Visitor
I may need to take out my rad, how easy is it to remove? Is it straight forward or is there a lot of other stuff that needs to come out first? Car is a 2007 manual with aircon.
cheers,
Martin.
- Thank you received: 332
- littletriple
- Visitor
So just drain down the rad, undo the obvious fixings/hoses & it should lift/jiggle out leaving the fan shroud & aircon rad in the car?
- Thank you received: 923
But as Yakuza says, it's dead easy on a non-air-con model?
- Thank you received: 116
Jalapeño, IISY?
- NicBe
- Visitor
- Thank you received: 260
Think i either unscrewed the fan and took it out with the radiator and shroud, or left shroud in there together with the fan. I cannot remember having any
problems.
I did not have to cut anything. But i have seen others do it.
Dunno why.
When my radiator was out, i made sure i had the belts ready and changed them when access was easy.maverick wrote: simple, we even took off my radiator when off-road to make replacing the Fan Belt easy!!
- littletriple
- Visitor
- NicBe
- Visitor
Drain fluid
Unbolt fan cowling 3 Bottom 2 top, remove bolts completely or they will fowl the fan when you lift it out
Remove top hose
Remove bottom hose
Unbolt rad, 2 10mm bolts at top sides of rad
Move cowl as far forward to engine as pos
Lift rad out, hand spin the fan as you lift to allow the bottom outlet space you'll see.
Takes longer to drain than remove
