Re:Review of Autool OBD2 Reader / Display
- Thank you received: 651
Hi Martin whats the one you have make and modelmlines wrote: I also have one and I am suspicious that mine is flattening the battery. Since having it the car has been used twice and each time it was flat. The first time I simply wondered if I had left the interior light on. The second time I knew all systems were off.
I can't find the original thread thanks
Jack
- GeorgeC
- Visitor
Thanks for the heads-up, Martin!mlines wrote: I also have one and I am suspicious that mine is flattening the battery. Since having it the car has been used twice and each time it was flat. The first time I simply wondered if I had left the interior light on. The second time I knew all systems were off.
I left my X50+ the Box and went for a GPS - Accy Socket powered - analogue Speedo.
- Thank you received: 368
I would need to check if oil temperature is supported, water temperature certainly is.
I am not aware of the dongle draining the battery with the ignition off, the LEDs go off the dongle when you switch the ignition off and the head unit looses the Bluetooth so if it is still drawing current it must be minimal.
Dongles are about £8-15, but you will need to use your phone or head unit.
- Thank you received: 1759
- GeorgeC
- Visitor
I should point out where I am coming from with my previous post. The OBD2 Reader in the review has limitations. It is hard wired and when I counted the number of wire conductors in the harness from the OBD Plug (under the dash) to the X50+ Head unit, it is one wire short, as in missing. On checking the harness end to end, two functions have been made common on one wire, this may be how the head unit is designed and be one reason for the battery to discharge when the Ignition is switched off.
When the Suzuki Tech Support rep visited my home about 12 months back, I asked about using the X50+ as a Speedo as I had just bought one for that purpose. The chap said not to plug any ODB device into a Jimny OBD socket as most devices were not compatible and I should use the 12V Accessory Socket to power a supplementary GPS Speedo, which I did.
I hope all that helps.
- new2jimny20
- Visitor
- GeorgeC
- Visitor
Your car is too early for OBD2, see this page for better information for your model: www.rhinopower.org/new2jimny20 wrote: Hello all. I'm new here and from Canada. I just purchased a 1998 Jimny and was wondering if anybody knows where, or if, I can buy an OBD2 for it? My engine is a F6A. I have searched but not certain if I can get one. Any help would be appreciated. Thanks
