BigJimnyMeet 2024
Length of M13a engine
- Thank you received: 651
21 May 2020 10:40 #222629
Replied by jackonlyjack on topic Length of M13a engine
Mine say's 3 degrees tilted back
The following user(s) said Thank You: minorsuzuki
21 May 2020 11:39 #222632
by Keithy
Replied by Keithy on topic Length of M13a engine
- minorsuzuki
- Junior Member
21 May 2020 12:23 #222636
by minorsuzuki
Morris Minor Traveller with M16a Liana engine and Jimny gearbox.
Replied by minorsuzuki on topic Length of M13a engine
Thanks Jack and Keith. Was that 5.4 degrees measured after calibrating for the sloping drive? My plan will be to jack up the front of the car until the engine is at the standard Jimny angle then take out the filler plug and see how much oil comes out.
21 May 2020 13:07 #222637
by Keithy
I wouldn't worry about the angle tbh......Jimny's get to some strange angles off the beaten track.
Congratulations on your recovery!
I worked at Major Minor in the late 80's.....saw some strange conversion there!
- Thank you received: 332
21 May 2020 21:11 #222649
Replied by yakuza on topic Length of M13a engine
I wouldn't worry about the gear oil either. When I done my oil changes I haven't been too particular on keeping the car level. I don't think a 5-10 degrees off would make the oil level too much off to make any difference. Using the correct oil and frequent changes is more important on a suzuki gearbox.
- minorsuzuki
- Junior Member
04 Oct 2020 12:14 #228768
by minorsuzuki
- Thank you received: 305
04 Oct 2020 12:37 #228770
by sniper
Replied by sniper on topic Length of M13a engine
Quality stuff, great build....
sniper
sniper
Time to create page: 0.131 seconds
