Length of M13a engine
- minorsuzuki
- Junior Member
- Thank you received: 6
Morris Minor Traveller with M16a Liana engine and Jimny gearbox.
- Thank you received: 252
Grey pick up Jimny
- minorsuzuki
- Junior Member
- Caelite
- Visitor
- minorsuzuki
- Junior Member
Caelite wrote: Does the Suzuki M series not share a common block, with different bore sleeving and stroke lengths. If this is the case surely the M18 or M15 would be better? Both are fairly common but with greater power outputs.
Correct, the bigger engine is my ultimate plan, but I would still need the Jimny engine and box to start with so I can get all the rear wheel drive bits off the engine to transfer onto the bigger capacity engine. For example the jimny engine mounts and top radiator hose look to be in roughly the right place.
- Thank you received: 551
Front pulley to bell housing joint is 18.5 inches.
BUT the rear of the cylinder head or something attached to it extends over the bell housing. I can't see what it is or if it can be removed, but the distance front pulley to rear of engine including this is 21 inches.
2009 jimny M13A VVT engine
Hope this helps
- minorsuzuki
- Junior Member
Point taken on the accuracy of your measurements.
- minorsuzuki
- Junior Member
- Thank you received: 1755
- minorsuzuki
- Junior Member
- Thank you received: 650
