BigJimnyMeet 2024
Immobiliser light stays on
- CharlesS
- Visitor
30 Jan 2018 23:10 #189006
by CharlesS
Replied by CharlesS on topic Immobiliser light stays on
Did you check to see if the fuel pump relay clicks when you turn the ignition to ON?
If the fuel pump relay does not click; some vehicles have a fuel pump safety reset that may need to be reset. Not sure if your vehicle has one or where it's located.
If the engine cranks over quickly, but does not start.... then the ignition system problem is not battery voltage related.
You need to start with the basics to determine why it wont start.
- mattsccm
- Visitor
31 Jan 2018 16:59 #189019
by mattsccm
Replied by mattsccm on topic Immobiliser light stays on
Sorted. The battery man had an idea. Fit new battery, lock up the car and then unlock. Job done. I assume that it was all to do with things being in the wrong sequence. A bit like trying to plug a mouse into a computer that's already switched on. Thanks for the help..
- mickt
- Visitor
31 Jan 2018 19:16 #189022
by mickt
Replied by mickt on topic Immobiliser light stays on
Nice one. Did you try to start it straight after he fitted the new battery before going through the door locking procedure?
- mattsccm
- Visitor
01 Feb 2018 19:24 #189038
by mattsccm
Yep. New battery, light stayed on, engine turned, nowt happened. Switched off, locked and unlocked doors and it worked perfectly.
Now what dimwit thought it a good idea to let such a problem happen. Mentioned it to my local garage this afternoon and was told that they have had a similar problem involving Vauxhauls and changing head lights
- mickt
- Visitor
01 Feb 2018 19:26 #189039
by mickt
Modern day electronics. Even the inventors don't really know how they work!!!!!
03 Feb 2018 21:35 #189077
by Rhinoman
Replied by Rhinoman on topic Immobiliser light stays on
I suspect what happened was that the battery voltage dropped too low and the ECU or immo reset.
- Thank you received: 260
09 Feb 2018 19:50 #189221
My Landrover (a Freelander) was a nightmare over flat batteries because the rear window winds down when you don't expect it to. Hated it.
Replied by helijohn on topic Immobiliser light stays on
mattsccm wrote: My Land Rover doesn't do this.
Time to create page: 0.094 seconds
