BigJimnyMeet 2024
× A place for more technical discussions. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Damd Dw, feel like setting it on fire grrrr.
  • Justin83
  • Visitor
  • Visitor
03 Apr 2017 06:05 #179862 by Justin83
I read a post the other day where a guy welded some snall box section too his, sorted it pretty well apparently.
So the bushes will likely be a waist of time?
Need Martin to chime in, I've pm'd him.
It's such a ball ache, gonna go ahead and do arb bushes and drop links + panhard bushes next.
  • DINGLE287
  • Visitor
  • Visitor
03 Apr 2017 09:59 #179864 by DINGLE287
Replied by DINGLE287 on topic Re:Damd Dw, feel like setting it on fire grrrr.
That's the kind of links I'm thinking of. Either making from scratch with stronger tube or bracing original 1 to strengthen. I've gotta take mine off and see if it's repairable first. Need to make room for it at work and just strip the while front Inc king pins etc I think
Sent from my SM-N9005 using Tapatalk
  • DINGLE287
  • Visitor
  • Visitor
03 Apr 2017 10:01 #179865 by DINGLE287
* lines I'm thinking of
  • Justin83
  • Visitor
  • Visitor
03 Apr 2017 13:31 #179869 by Justin83
Right I've now got super pro panhard and antiroll bar bushes, new drop links, and later 2009 on radius arm to chassis bushes coming... and the said offending oil seal.
Any tips on fitting the bushes?
  • Riccy
  • Riccy's Avatar
  • Banned
  • Banned
  • J999 MNY Bashing around Carlisle
03 Apr 2017 17:27 #179875 by Riccy
Justin83 wrote: Right I've now got super pro panhard and antiroll bar bushes, new drop links, and later 2009 on radius arm to chassis bushes coming... and the said offending oil seal.
panhard & ARB bushes are easy with some threaded rod and some various size sockets.
The radius arms are a really big press (30T +) or drill out the rubber and cut the metal band out with a hacksaw. not easy and takes ages. I think there was something about doing this in the big jimny blog. the new ones will need a press if standard (mine are polybushes and in 2 parts so no press needed).
Riccy
  • Justin83
  • Visitor
  • Visitor
05 Apr 2017 18:45 #179935 by Justin83
Cheers pal, maybe a garage job for those then....
Just fitted the panhard bushes and new oil seal, also removed some shims to make it just one at the bottom to see if there was too much preloaded causing it...
Still dangerous to brake from 50mph.
Running out of options here now.
Not sure whether to get the wheel bearings done as I've read they are very hard to diagnose and people have fixed death wobble by Changing them even tho they felt fine...
Dreading having the radius arm out, awkward as it's our only car had enough now uuuurgh.
Snapped a king pin nut earlier but thankfully i was able to cut a groove in it with my dremel and it can out with a screwdriver!!!
05 Apr 2017 19:37 #179941 by Rhinoman
Fitting poly bushes to my panhard was what caused my death wobble.
05 Apr 2017 19:44 #179942 by X8GGY
Rhinoman wrote: Fitting poly bushes to my panhard was what caused my death wobble.
Fitting a certain brand caused it ;) Fitting another brand (Bits4Vits!) sorted it? ;)
05 Apr 2017 21:20 #179945 by Keithy
[quote="Justin83" post=179935
[/quote] Is the wobble only under braking?
  • Justin83
  • Visitor
  • Visitor
05 Apr 2017 21:23 #179946 by Justin83
Really!! I used super pro ?
  • Justin83
  • Visitor
  • Visitor
06 Apr 2017 18:22 #179976 by Justin83
I will add it only does it when we brake between 60- 45mph.... might see if the pads are sticking?
  • Justin83
  • Visitor
  • Visitor
06 Apr 2017 18:23 #179977 by Justin83
I done the discs about 3k ago and pads, its not a warped disc its a sway around and bounce wheel to wheel wobble!
Time to create page: 0.148 seconds
Powered by Kunena Forum
