BigJimnyMeet 2024
IT WONT START
- Paterson
- Visitor
25 Mar 2016 22:17 #164361
by Paterson
IT WONT START was created by Paterson
Hi my poor jimny will not start
I had been out last Sunday off roading local lanes nothing to drastic few wet muddy bits on way home I noticed steering/suspension had developed an issue couldn't hold it in a straight line thought I'd take it to my local jet wash give it a blast off so it was clean to look over everything to try find what was causing this .
So Monday
Moved car onto the drive found bushes on the radius arms had seen better days and a track rod end so I left the car where it was
Today (Friday) fitted all the new parts as planned new poly bushes and the trackrod also spotted it needed new pads so dashed out to get some ....fitted everything all done drop the car back on its wheels to go for a test drive
The problem
Car turns over but doesn't fire
so I started with the basics unplugged every connector i could find in the engine bay all look nice and dry inside sprayed with quick mist of wd40 then clicked back together tried turning it over same again cranks doesn't fire
Next on the list checked all the wiring for damage can't see anything that would have been caught or snagged when lowering the axle to change the bushes
Checked the fuses in the engine bay on the drivers side
Checked fuses under the steering column
All fine
Checked for a spark removed a plug put it in the ht lead and cranked no spark the plug was dry so I checked for fuel at the fuel rail
Removed hose cranked it again nothing
After much reading on the internet found the fuel pump relay location removed relay checked it can hear it clicking .
I then put 12 v Into the loom I had fuel instantly at the rail so that sais pumps good
Now I'm out of ideas I've searched the internet high and low but no luck on finding a match to my car
I did find a few posts about imobilizer faults I've only owned the car a few weeks so I'm unfamiliar with the sequence on the dash lights when I turn on the ignition I don't have a car with a padlock for the imobilizer shown or an engine managment light
Help!!!
Thanks
So Monday
The problem
All fine
Help!!!
Thanks
- Thank you received: 252
25 Mar 2016 22:54 #164364
by j999pre
Grey pick up Jimny
Replied by j999pre on topic IT WONT START
Check the wiring to both relays. Look for corroded wires maybe
Grey pick up Jimny
- Paterson
- Visitor
26 Mar 2016 14:39 #164390
by Paterson
Replied by Paterson on topic IT WONT START
Today I've physicals checked all the fuses not just with the teat light checked wiring to the relays all looks good.. Took the dials out to check if somebody had removed the bulbs for the immobiliser swapped them all about I don't seem to have the light on the dash I keep reading about.... I have checked coil around key..... I have grey key non central locking
- skywalker65
- Premium Member
- Thank you received: 20
27 Mar 2016 07:16 #164408
by skywalker65
If in doubt ...... Flat out ??
Replied by skywalker65 on topic IT WONT START
No spark and no fuel suggests crank sensor. Most injection systems rely on the engine Ecu receiving a signal from the sensor to start everything going
- Paterson
- Visitor
27 Mar 2016 08:18 #164409
by Paterson
Ok thankyou I'm hopefully I'm borrowing a decent code reader off of a friend to try and check live data see if it's getting a signal ....I did notice last thing yesterday the rev counter doesn't move at all when I'm cranking so this would make sense
- gusthegorilla
- Thank you received: 190
27 Mar 2016 08:27 #164410
by gusthegorilla
I'm planning to live forever.....so far, so good !!
Replied by gusthegorilla on topic IT WONT START
Be aware also that a crank sensor fault has a habit of NOT showing up on the fault reader. .....I was caught out by this small but significant fact, and wasted days.....
- Paterson
- Visitor
27 Mar 2016 19:02 #164461
by Paterson
Ok thanks I think I'm just going to order cam and crankshaft sensors my friend seems to have disappeared off the face of the planet with the code reader anyway ....
- littletriple
- Visitor
30 Mar 2016 18:41 #164660
by littletriple
Replied by littletriple on topic IT WONT START
Interested in what you find. Ours has just developed a similar problem. It cranks but won't fire. I can smell petrol at the exhaust so suspect there's no sparks. It was fine in the evening but wouldn't start the next morning. All suggestions welcome .
- Paterson
- Visitor
30 Mar 2016 21:25 #164667
by Paterson
I'm still none the wiser on mine I've replaced the cam and crankshaft sensors Still the same symptom ..cranks doesnt start no fuel at the rail and no spark .
- skywalker65
- Premium Member
31 Mar 2016 06:07 - 31 Mar 2016 06:11 #164679
by skywalker65
Start with basic checks , power to the coils and fuel pump ? Can you hear any clicking from the injectors. Could be an Ecu failure but would think that's pretty rare. Sounds like a power supply issue. Someone had a similar issue on here and he traced it to.a badly corroded wire from the fuse relay box area. Had to untape the harness slightly to find it as water he got in
Last edit: 31 Mar 2016 06:11 by skywalker65.
- Paterson
- Visitor
31 Mar 2016 19:34 #164710
by Paterson
This is my last resort I'll remove all the loom tape and check everything for continuity but I'll have to source a wiring diagram of what does what
- littletriple
- Visitor
01 Apr 2016 07:33 #164726
by littletriple
well, embarrassingly it seems ours was just flooded. Didn't realise that was even possible with "modern" injected engines.
But this raises another question. I have always felt it runs way rich on cold starts & idles at near 3000 until warm when all returns to normal. The garage also reckon it is over fuelling when cold which could partly explain the flooding. Is this usual & does anyone know if it can it be adjusted?
Time to create page: 0.193 seconds
