1.6 engine conversion without using adapter kit
- gus2000
- Visitor
I approached some modifications as proposed in
www.rumbozeroexpediciones.com/app/.../TT-102+SUZUKI+1600.pdf
G16b Engine from Suzuki baleno 2001.
Without using engine-gearbox adapter kit.
Aligner is constructed to ensure proper alignment engine box
Box holes are enlarged to accommodate the knock pin and allow the motor screw
At the bottom we drilled the two parts (engine and gearbox) simultaneously to insert a "pin" which allow the correct centering of the two parts
Lower coupling piece
Jimny oil strainer with 1.6 connection welded
Flywheel of jimny in 1,6 engine
Jimny phonic wheel in the 1.6 engine. You must be careful to place it in the correct angle
Test 1,6 injectors.
Right engine modifications
Left engine modifications
Assembly engine gearbox set
Motor circuit filled with oil, using a soda bottle pressurized with air. The connection is made in the oil pressure switch.
Relocation exhaust pipe
Close-fitting
Prolongation of the lower support from the exhaust
Ignition timing is correct.
Ready to use
Thank you very much to those who helped me in the work
Best regards. Gustavo
- craigy123
- Visitor
- GraphicX
- Visitor
- fc.tanou
- Visitor
- gus2000
- Visitor
fc.tanou wrote: My friend can you tell me what is the correct position of the ring behind of the camshaft.the camshaft on the front of engine is it in timing?
Hello,
For install the phonic wheel
1) put the engine in "timming belt instalation" (crankshaft and camshaft) ..
2) insert the phonic wheel (whith the front face properly) as the figure
gustavo
- Cider
- Visitor
A great write up.........
- GraphicX
- Visitor
- Johnniehec
- Thank you received: 56
Cheers
John.
- Vasile
- Visitor
- gus2000
- Visitor
- Thejimnythatcould
- Visitor
And crank set up
To tdc? Then the line on head with the top of the tooth or the centre?
