BigJimnyMeet 2024
Convert push button to stick shift transfer box
- Old Blind Dog
- Visitor
26 Jul 2014 07:18 #120719
by Old Blind Dog
Replied by Old Blind Dog on topic Convert push button to stick shift transfer box
To fit sammy tcase in 2005-2011 Jimny with manual transmission, you'd better get diffs off 2011 Jimny with MT (left hand drive) or 2002+ Jimny Wide with MT (right hand drive JDM). Both use 3.4 ratio. Works great with 4.16 and 31".
10 Nov 2015 16:48 #155909
by Bosanek
Replied by Bosanek on topic Convert push button to stick shift transfer box
Just to confirm - it IS NOT possible to put a lever in an electric transfer box then? Or is it?
Sorry for reviving an old topic but I got a bit fed up with those flimsy 4WD buttons and I'm looking to get rid of them. It's supposed to be an offroader, not a playstation.
I will never understand why Suzuki changed it from lever to the buttons in the Jimny.
If it was for the sake of modernity and convenience, well, Jimny might be modern compared to the Samurai, bot globally, it ain't modern a lot. Toyota Land Cruiser Prados of the late 2000s still had the lever, just to mention one example. And Prados are certainly modern.
- Thank you received: 252
10 Nov 2015 16:53 #155911
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Convert push button to stick shift transfer box
I just finished this conversion a few weeks back for a pal.
I used a non vvt gearbox and a rocklobster transfer box to run his 31" tyres
Grey pick up Jimny
11 Nov 2015 12:18 #155972
by Bosanek
Your conversion involved changing the entire gearbox and the transfer box.
I am interested if the existing electric transfer box can be adapted to accept the classic lever like in pre-VVT Jimnys.
11 Nov 2015 17:58 #156002
by j999pre
Grey pick up Jimny
Maybe you could put push button transfer gears inside a manual transfer box? That would keep your ratios correct? Not something I know that is possible though but someone may.
Grey pick up Jimny
11 Nov 2015 22:04 - 11 Nov 2015 22:06 #156046
by Rhinoman
Replied by Rhinoman on topic Convert push button to stick shift transfer box
I don't see why it couldn't be converted to a lever, the electric shift is a motor that just moves a shaft in and out, it would take some fabrication though. I don't have any issues with the buttons.
Last edit: 11 Nov 2015 22:06 by Rhinoman.
06 Sep 2021 15:31 #238286
by Ogalex
Replied by Ogalex on topic Convert push button to stick shift transfer box
Hello,
Sorry to revive this old topic. I desperately need to convert the transfer case push buttons to manual of my 2005 Jimny. Anyone could help?
Cheers.
Cheers.
- Thank you received: 653
06 Sep 2021 16:12 #238291
Replied by jackonlyjack on topic Convert push button to stick shift transfer box
Are you still using vacuum hubs ? or manual locking hubs
Under the carpet near hand break there is a plate that has four screws
Time to create page: 0.122 seconds
