Best rear diff lock!
- TomDK
- Visitor
ilten wrote: Coming from a VW Iltis with front & rear mechanical 100% lockers engaged by a lever, I wanted the same for my Jimny. I searched long and hard, but to my knowledge it does not exist. There was a member on pirate4x4.com who build a cable actuated locker for a Samurai rear which theoretically could be used in a Jimny axle, but it had some problems and never left the prototype stadium. So if you are really picky, and money is no object for you whatsoever, just find a company with capable engeniers and enough cnc manufacturing capabilities and have them build you a one off locker. If your pockets are deep enough, it can be done. I went the more reasonable route and installed front and rear ARB lockers. I have the small ARB compressor coupled with a 1l steel air tank under the passenger seat. Once filled it lasts for about 15 or so engagements of the locker before refilling. I think it's reasonable. Yes, it makes some noise, but it's not like it's running constantly. And the ARB lockers are fast!
Good luck in your quest to find the ultimate locker, but it might be easier to just buy a different car or axles.
Exactly
There's no point in trying to reinvent the wheel when ARB lockers are tried and tested. And they work
- JuanGuillie
- Visitor
You have to spend some money but for me personnaly it's worth every penny !
I fitted it with a compressor with 10 L air-drum.
I do fill it up just before i start my offroad day. Normally it's OK for the rest of the day with no refilling.
Compressor and air tank did cost me around 80£.
- Thank you received: 1761
- Thank you received: 332
But to have a daily driver with a locker instead of a diff, not for me. I am too old.
