Re:"Jimny Lean"
- Thank you received: 1761
- Thank you received: 82
Lambert wrote: Sorry. Longest pair to the front and the longest of those to the driver side.
Oh for the love of St Bernard the seer of mechanical mishaps ...............
SHite.......
Thanks Lambert
Heavy Duty Transfer Box Brackets, 2-inch Black Raptor lift kit, caster adjusters, Rust removed and stich welded new sections. Galvanised Chassis. Body,Engine,transmission swap. Anti Rollbar Roll / Sway Bar / DAVES ARB disconnect kit.Osram Night Breaker Head light mod and white 501 led side lights.
- Thank you received: 653
Also thats why the driver side front spring is longer .......so no spacer should be needed
About Wee Jimmy : www.bigjimny.com/index.php/forum/8-my-ji...-first-jimny?start=0
- Thank you received: 370
I haven't checked to see if the previous owner fitted a drivers side spacer, but if they didn't are these still available, bits4vits/jimnys seems to have closed.
Is measuring from wheel bearing to body work accurate enough?
Ta
Check out eBay.
I found Zookbob on ebay, he sells 1" spacers for front suspension, so will check mine out and order one.
I might have found part of the problem, I have only had the car a month and checked tyre pressures, the rear are 23.5psi, the front drivers side 25.5 psi and the front passenger is only 20.5psi. Looks like they put the wrong pressure in and I have a very slow leak.
I feel a bit of a numpty not to have checked these first.
- Reason2doubt
- Thank you received: 100
I have just ordered 3x 1.5cm spacers and a 2.5cm spacer for the front-drivers side spring to even this out. I bought the other spacers as I anticipate the springs sagging a little bit further with the impending arrival of a winch on the front, as well as a roof-top tent on the back.
Looking forward to seeing the result when I get them in-place.
