Crankshaft sensor
- Adamski
- Visitor
- Thank you received: 34
Former owner of Little "Ooky", who has now started a new life in Shetland
- zaine
- Visitor
i had exactly the same problems, replaced both sensors from an engine in work, fixed
- adam
- Visitor
I have been having the same problems when I have done a long drive then park up my jim just dies. I leave it for 5-10 mins and starts after a bit of a chug!!
Mine is a 2000 model so how many and which sensors do I have?
adam wrote: Hi, I know this is really old now but just checking with you.
2 sensors, one at the front of the engine, the second, a real pig to get at. Have a look at Martin's Tips for details of how to change / test them. expect to pay £40 ish each
- adam
- Visitor
When you look at your engine does it have a black plastic cover ontop of the engine or is it alloy ?
- adam
- Visitor
adam wrote: Its a hard top and I think its a metal cover
Ok, so its most probably the G13BB engine ( the older engines, same as the SJ's ).
I believe the sensor is at the front of the sump... the oil pump is tapped to accept it. There should be an exploded "under bonnet" view in Martin's How to section ... Failing that, try searching the archive for "G13BB Crank Sensor" ... Ill have a trawl too, see if I can find anything
- adam
- Visitor
There is an engine management garage in town I might take it to for them to have a look.. Thanks for your help. At least I kind of know what to say to them now!
- jonesyba420
- Visitor
- Damohick
- Visitor
