Crankshaft sensor
- Adamski
- Visitor
- Thank you received: 581
You might not even have one, AFAIK only the Spanish built convertibles have one, you don't say which car and engine you have.
The twin cam engine has just the cam sensor, that can be changed very easily it: is at the top front of the engine, right hand side as you face the engine.
You need the fault codes read unless you like gambling with quite a lot of money.
A sensor fault is usually poor running: the engine light comes on on the motorway/stalling when hot, cooling the sensor will allow an immediate restart.
- Adamski
- Visitor
that is exactly the fault I have. I think you maybe right about it being the cam sensor if that's the sensor at the front. I think I must have got mixed up and thought that was the Crankshaft sensor. I have a 2002 hardtop jimny special with twin cam. and idea how much a cam sensor will set me back?
thanks,
Adam
- Top Rope Terry
- Visitor
The first engine below is the single overhead cam G13BB engine, fitted to all Jimnys prior to 2001 and to Spanish softop Jimnys as late as 2004. AS you can see it if only fitted with a Camshaft Position Sensor (Number 7 in the picture)
Press the CONTROL key on your keyboard whilst scrolling the wheel on you mouse to zoom in
From 2001 onwards the Jimnys were fitted with an double overhead camshaft M13AA engine (except Spanish Softtops). These have both a Camshaft Sensor (Number 7) and a Crankshaft Sensor (Number 5). This also applies to the later VVT engine from 2005 onwards.
You likely have both sensors, you need to find out which one to change. If the engine stops altogether, likely it is the cam sensor.
If the crank sensor goes the engine light comes on and it runs in limp home mode.
You can buy an OBD2 fault code reader from eBay for about £20 that will work on a 2002, allow you to find which sensor is faulty and clear the error code.
The reader will work on most petrol cars from 2003, but the Jimny complied with OBD2 in 2000 (Japanese built).
There are cam sensors on eBay for about £35.
- Adamski
- Visitor
I got them backwards
ahh in that case I do think it is the Crankshaft sensor which has gone. is that the sensor at the front of the engine? my symptoms are when it gets hot (after being stuck in a traffic jam) the rev needle started to bounce all over and the engine management light flashes on and off killing the power. if I turn it off and straight on it still happens, if I let it cool for 5 minutes the car runs fine again.
- Nelson83
- Visitor
The one at the front of the engine is easy to get to, but the one near the alternator was a bit of a pig. I used a large breaker bar to lever the alternator sideways after id slackened the bolts and then used 3 extension bars (foot long) on the end of the rachet to undo the nut. Took a little over 1 hour to do both with minimal tools.
- Thank you received: 34
Former owner of Little "Ooky", who has now started a new life in Shetland
- Adamski
- Visitor
- Adamski
- Visitor
I think I've identified the faulty sensor to be the camshaft sensor using the old water technique to cool the sensors till the problem goes away. I've ordered a new sensor from Suzuki at a cost of £62 and it will arrive on Tuesday. Fingers crossed that this fixes the problem!
And so it continues ....
I have replaced the Camshaft Sensor and still have exactly the same problem. Does this point towards the Crankshaft Sensor being faulty? or could I have bought a knackered camshaft sensor from the dealer (a long shot I know but just want to be certain). Im getting sick of this problem so if a new Crankshaft Sensor is required I will just fit one, then both sensors have been changed and will have to hope for the best.
Any thoughts would be greatly appreciated .
Adam
