Fitting 2" body lift
- Back in Black
- Visitor
(first post so please go easy on me!!)
I am fitting (fingers crossed) a JimnyBits 2" body lift at the weekend, having got a height complex after looking at the other Jimnys here, and didn't want to stand out too much at Wagtails. I have done a trial run and found how to access all 8 bolts. I have also ordered extended brake lines, as I have already fitted 2" spacers on the springs and was concerned the current lines might get a bit stretched.
I have noticed that the front bumper mounts will no-longer line up, and I have read that sometimes the gear stick and 4 wheel drive selector no longer work correctly without some tweaks. What alse do I need to be aware of?
If you have any tips they, will be gratefully reiceved.
- Az1987
- Visitor
- VAXXi
- Visitor
- srcars
- Visitor
I also had to adapt the transfer box lever to allow 4wd low to engage. I removed the lever from above and then cut it, rotated the two halves slightly and rewelded it back togeather. Most people get it bent for them but it needs some serious heat.
Watch your air pipes for the free wheeling hubs and your brake lines as you lift it but other than that it was very straight forward and done in a few hours single handed Just take your time when you lift to make sure nothing is caught.
My MOT man was pleased to see the brake balance bracket on the rear axle adapted which is an easy fix.
Hope that helps a bit
- Back in Black
- Visitor
I feel more confident now that I will be able to pull it off.
I'll post an update when I've finished
Thanks again.......
- Johnniehec
- Thank you received: 56
There's no such thing as a stupid question on here and even if it's been asked before you'll still get answers or directed to the relevant info.
My DIY body lift turned out at 32mm! (length of nylon bar cut into eight bits) slacken both ends of both steering knuckles but dont remove the bolts there's a flat on the splined shafts where the bolts sit and the one on the steering box is about an inch long, that's where I got the necessary extension. It's also the one that's likely to be seized.I don't think the bottom front bumper brackets can be shifted/modified by 2ins as they're fixed closely to the bottom of the cross member, but I'm sure someone can correct me if I'm wrong. My bumper is cut so I don't have bottom mounts anyway. the brake pipes/hoses to watch are the two short flexys between body and chassis below the master cylinder, unbolt the union from the chassis and bend the pipes slightly as you lift then put in a short plate to extend the bracket. The rear flexy is not affected by a body lift, the fronts are. You'll also need to take the cover off the fuel tank filler pipes under the rear offside wheelarch and loosen the jubilee clips, maybe get some new ones in case.The main gear lever should be OK but the transfer lever does need adjusting otherwise it'll be difficult to select low ratio and/or jump back into high (right pain in the a*%e when you're competing in a trial!) The standard lever is a complex bend to the front and left it's easy to take out (after the lift cos there's more clearance) I cut mine 3/4 way through and straightened the bend to the front and welded it up (looking at it now from right or left it looks straight if that makes sense) hope this might help a bit.
Cheers,
John.
- VAXXi
- Visitor
Johnniehec wrote: Welcome Back in Black,
Aha, now I understand why a bash plate is mounted on mine ! so, basic idea is that you get a piece of steel and bend it; the top part gets to support the bumper mounts, bottom part gets attached to where the bumper used to be mounted.
- renard38
- Visitor
- Back in Black
- Visitor
Can't get the rear to detach from the chassis!!! I've banged and oiled but everytime I jack the body the chassis comes up too!?!? Anyone get stuck here.
Having a break and lunch while rain stops play.
I thought the front was too easy
- Keefe
- Visitor
Could the rear bolts be at too much of an angle and so are 'gripping' the chassis?
Try taking the front out and lifting the body at the front and rear at the same time, perhaps??
K
- renard38
- Visitor
- Back in Black
- Visitor
The washer on the left re-most stud had managed to get threaded on!! Soaking wet and desperate I tried using a pry bar to twist it off - 1 1/2 hours for one nut!
I had some issues with lining the studs up when I had the spacers finally in place. I have become very adept with trolley jacks. Landed up with three extras from neighbours.
First thing tomorrow need to get the last bolt lined up at front passenger side!
Thank you for the tips earlier. Can't wait for update three ;(
