BigJimnyMeet 2024
getting better mpg
27 Jul 2022 17:53 #244244
by danielbz
getting better mpg was created by danielbz
hello
i have seen some suzuki jimny owners with suzuki jimny engine 1.5 with 40mpg fuel economy,
how can this persons achieve this? most i can do is 29 mpgs
regards
regards
- Thank you received: 167
27 Jul 2022 20:06 #244246
by 300bhpton
Replied by 300bhpton on topic getting better mpg
Mpg will depend on how you drive, where you drive and any mods you have.
27 Jul 2022 20:17 #244247
by danielbz
Replied by danielbz on topic getting better mpg
im driving conservative grandpa style
27 Jul 2022 21:30 #244248
by 300bhpton
29mpg does seem low. Is this from the OBC? What speeds do you drive at?
Are you in the U.K.?
I’ve never seen more than 39mpg from mine. But I’m on All Terrain tyres these days and a few mods. Normal running about I see more like 33-34mpg. Running at over 60mph on dual carriageways seems to limit mpg. But sedate running on A and B roads should see high 30’s.
27 Jul 2022 21:49 #244249
by danielbz
im using a non traffic road, i drive 50 mph when going uphill and i go downhill in N, im not in the UK, what mods do you have?
- Thank you received: 368
27 Jul 2022 23:11 #244250
Replied by DrRobin on topic getting better mpg
Are you imperial or US gallon? Imperial gallon is equal to 1.2 US gallons.
Also what octane rating do you have and how much Ethanol?
The differences are small but might add up.
Robin
Robin
28 Jul 2022 02:23 #244251
by danielbz
US gallon
91 octane, no ethanol
- Thank you received: 1759
28 Jul 2022 03:31 #244252
Replied by Lambert on topic getting better mpg
Driving down hill in neutral that is coasting is not good. First it reduces your control of the vehicle as you have no engine braking effect which in turn increases reliance on the wheel brakes which can cause them to overheat. Secondly the engine will revert to idle in neutral which requires it to burn fuel, when going down hill in gear the ECU detects this and virtually stops fuel supply, the effect may be small but it does increase mpg.
28 Jul 2022 04:40 #244253
by Old Neil
Replied by Old Neil on topic Re:getting better mpg
Can you use 91 in a series 4 my series 3 staits minimum 95 ?
Sent from my SM-A336E using Tapatalk
- Doctorchris
- Senior Member
28 Jul 2022 07:06 #244254
by Doctorchris
Replied by Doctorchris on topic getting better mpg
Your US gallon figure converts to nearly 35 mpg in Imperial measures, which is better.
I often achieve 45 mpg but that is on smooth tarmac, change up quickly through the gears and keep speeds low.
28 Jul 2022 07:47 #244255
by saxj
Replied by saxj on topic getting better mpg
Great theory, but in practice coasting in neutral uses less fuel.Driving down hill in neutral that is coasting is not good. First it reduces your control of the vehicle as you have no engine braking effect which in turn increases reliance on the wheel brakes which can cause them to overheat. Secondly the engine will revert to idle in neutral which requires it to burn fuel, when going down hill in gear the ECU detects this and virtually stops fuel supply, the effect may be small but it does increase mpg.
- Bill Portland
- Thank you received: 77
28 Jul 2022 08:17 #244256
by Bill Portland
Replied by Bill Portland on topic getting better mpg
My very standard gen 4 still achieving a lifetime average of over 42mpg (UK). No motorways near me but otherwise regular A & B road driving. I rarely cane it though.
