BigJimnyMeet 2024
Suzuki Jimny 2005 automatic powerless on highway
- GeorgiosP
- Visitor
18 Nov 2021 20:52 #240189
by GeorgiosP
Replied by GeorgiosP on topic Suzuki Jimny 2005 automatic powerless on highway
We replaced the throttle because it had problem. We checked that with the diagnostic tool and the code was fort the gas throttle. So we replaced it but nothing happend only the lamp turned off. The only modification is general grabber at3 tires 205/75-15. There arent any smells from the gearbox, only sometimes som smell from gas. In N its revs good no problem, but when you are on the highway you cant go more than 90km/h and the car havent power to rev up more than 4000rpm i dont know if its with 3rd or 4 gear. I dont think its normal i dont know any other with automatic gearbox in Sweden. And its not big hills its very low gradient hills. Its the highway you Can not Call them hills the seller who sold the car to me told me its a new Exhaust and cat. I dont know what to do, i have booked an checkup on Suzuki 8/12.
- GeorgiosP
- Visitor
18 Nov 2021 20:58 #240190
by GeorgiosP
Here is some photos of the car
- Thank you received: 368
18 Nov 2021 22:35 #240193
Replied by DrRobin on topic Suzuki Jimny 2005 automatic powerless on highway
The code you have P0121 is stating that the throttle position sensor has a range problem, see the following obd2pros.com/dtc-codes/p0121/
The following text is taken from this link
Causes
There are a few primary factors in your vehicle that may cause a P0121 trouble code:
That the TPS has an intermittent up or an internal short.
That it is rubbing the harness and causing a short or open in the wiring.
There is a bad connection at the TPS.
That the PCM is bad (although this cause is less likely).
That there is corrosion or water in the sensor or connector.
Any one of these could trigger a P0121 trouble code to occur.
Symptoms
There are a number of symptoms that a vehicle may be experiencing, should a P0121 trouble code be present with the vehicle:
The check engine light comes on.
The ECM will cause the check engine light to come on. This will put the vehicle in failsafe mode, which means that it will cut off the current to the throttle actuator, put the throttle valve at a little less than 6 degrees of an opening.
The ECM with control fuel injection and timing to control the speed of the engine.
You will be able to drive your vehicle, but only slowly and with very limited response to the throttle.
The engine may not accelerate as smoothly as before.
The engine may idle higher than it normally does.
This seems to fit, your Jimny is running on reduced power or reduced throttle opening. The links suggests checking the sensor, but also the wiring.
Robin
Causes
Symptoms
Robin
- GeorgiosP
- Visitor
18 Nov 2021 22:54 #240194
by GeorgiosP
hi and thank you very much for your help, it is very much appreciated. when the lamp was lit, the car went into safe mode, it then had no power at all and did not rev high at all. then I left the car in the workshop and they replaced the throttle house and tps sensor. if there were still problems would not the lamp start to shine again? the car has power at low speeds. from the start it is very alert but as soon as there is a small hill it loses speed.
- GeorgiosP
- Visitor
18 Nov 2021 22:57 #240195
by GeorgiosP
I would try to take a video tomorrow and post it here so you can see what the problem is and how it works.
- GeorgiosP
- Visitor
18 Nov 2021 23:18 #240196
by GeorgiosP
I can also tell you that the fuel consumption is very high its about 11-12L/100km with 35L i do maximum 300km.
- GeorgiosP
- Visitor
19 Nov 2021 09:14 #240199
by GeorgiosP
Here is two videos of todays driving
1.
2.
1.
2.
19 Nov 2021 09:47 #240203
Unfortunately I don't have any experience of a Jimny auto, so can't really comment if what you are seeing regarding gear changes are correct. It probably is, it is changing up somewhere around 4,500 RPM.
Looking at you RPM vs Speed, it is just lacking in power, especially at the top end. There are a wide number of causes for this, too many to list here, but a Google search gives this article which lists most of them.
cartreatments.com/car-losing-power-when-accelerating/
The poor fuel economy is also a clue.
I would check the following:
1) Air Filter, is it nice a clean or clogged, this is a 5 minute job. If you can't get air in, especially at the higher revs it will limit power.
2) Spark plugs, take out the plugs and check the colour against a chart. Do they look black with soot? The plugs will confirm if your engine is running rich. Depending on what they look like will give us a clue as to what to check next.
Also check the coil packs for cracks (these can sometimes be very small, so clean the coils with contact cleaner and inspect under a bright light). Coils are under high load at higher rpm/power and a weak coil will be more of a problem at higher rpm, producing a poor spark and poor burning of the fuel. You should see this in the O2 sensor, but you need to be graphing the sensors whilst driving.
3) Exhaust, a blocked or restrictive exhaust will limit power again especially at high revs. You said the exhaust was changed, was it the whole exhaust or just part of it? Apparently the first CAT (manifold) break apart and clog the second CAT/box on Jimny's, if it hasn't been changed this might have happened.
4) Fuel. Has your fuel changed? Gone from premium unleaded to a lower octane rating or more Ethanol? Or is it just dirty fuel or water in the fuel? This is difficult to answer if you haven't had the car long and it has always been like this.
5) After that it probably gets more involved. If your engine is running rich the fuel pump + filter are probably okay, it's more likely to be air/mixture/timing.
If the filter is okay, check the MAF sensor.
Suspect the O2 (Lambda) sensor, especially as the exhaust was changed.
Timing, CAM/Crank position sensor.
Suzuki might find the problem, the trouble is if there aren't any codes, they might check sensor graphs but are more likely to start throwing new parts at it until they strike lucky, time is money to them and these problems are often difficult to fix without spending a lot of time.
Hope that helps.
Robin
Hope that helps.
Robin
- Thank you received: 1759
19 Nov 2021 11:13 #240204
Replied by Lambert on topic Suzuki Jimny 2005 automatic powerless on highway
That's doing what Spare Jimny did when we first got her, not reving all the way to full power before shifting. This was simply a result of too much slack in the inner cable of the throttle pedal. I loosened the outer cable in the bracket near the throttle body and removed most but not all of the free play in the inner cable and re-tightened the outer. This allowed the throttle to open correctly and give the ability to climb hills. Essentially the throttle was only open to at best 3/4 which is not helpful. There was a little slack in the cable on Temeraire but not enough to really worry about. It's also worth noting that having heavy duty floor mats as I do because of the farm can have a similar effect if they move under the accelerator pedal.
- GeorgiosP
- Visitor
26 Nov 2021 17:46 #240343
by GeorgiosP
Hi guys, i have now solved the problem it was the little cat with position under the engine, i mounted away the lamba and the car was like another car so i ordered a new cat with branch pipe. Thanks everybody for your inputs!
- Jargal
- Visitor
16 Mar 2022 16:26 #242344
by Jargal
Replied by Jargal on topic Suzuki Jimny 2005 automatic powerless on highway
Hi GeoriosP,
Glad to hear you solved this issue. Could you please put photo of lambda sensor that you replaced? Where this sensor actually placed?
Regards,
Jargal
Regards,
Jargal
Time to create page: 0.154 seconds
