BigJimnyMeet 2024
Lockers
- Jemjem
- Visitor
- Thank you received: 1755
15 Oct 2021 04:53 #239415
Notwithstanding the fairly monstrous cost of a pair of arb air lockers and compressor and fitting I would have a double locked Jimny in a heartbeat, coupled with some appropriate tyres it would be essentially unstoppable. However at a cost of potentially 2 to 2.5 grand I'm happy to wait, for now.
The following user(s) said Thank You: lookonimages, Jemjem
The topic has been locked.
15 Oct 2021 06:43 #239417
by Busta
Definitely worthwhile if you regularly drive in places where your wheels come off the ground.
ARB air lockers are arguably the best but also the most expensive option.
Chinese ARB copies are available that will save a few hundred pounds.
X Shock Dakar make and electric locking rear diff that is also a torsen LSD. This is around £700 and doesn't need a compressor to run so cheaper to install. When not a locked diff, it still gives you the traction advantages of a limited slip diff so it's a really good option and the one I'd go for.
Then you have "automatic" lockers like the Kaiser locker and Lockright. These fundamentally change how the diff works, making it better for traction off-road but not so good for road driving. They are sensitive to how they are installed and can be quite crude in operation.
Lastly you have the option of welding the diffs. It's cheap and dirty but very effective off-road. Most people weld the rear but that does impact on-road driving and reduce manoeuvrability. I have welded my front diff. It's made the Jimny a monster off-road without affecting day-to-day 2wd driving. I also have a Quaife LSD in the rear, but that's not a locker.
The following user(s) said Thank You: Jemjem
- Thank you received: 165
15 Oct 2021 09:27 #239418
by 300bhpton
As in depends on where you will be driving, how often and what you are trying to achieve.
Lockers provide many benefits. But also some downsides, such as a poor turning circle when engaged. Require manual intervention on when to use them or more importantly, when not to use them. And are only suitable for use in certain situations. It is also probably true that much of the time you wouldn't actually 'need' them to conquer the terrain you are on.
Unless you are rock crawling where you want no wheel slip to engage your traction adders. I think an ATB setup is likely a better compromise, especially when combined with traction control. This would then be a passive system requiring no user intervention at all for it to work, it wouldn't impact your turning circle and would offer benefits on all surfaces, including when in 2wd on the road.
But as said, it really does depend.
Slightly opposing the two views above. But I'd say it depends.Hey everyone! I have a 2014 Jimny and I'm wondering what everyone's experience with lockers are? Are they worth getting and if so, what kind did you get and what was your approx cost?
15 Oct 2021 09:34 #239419
by 300bhpton
Not knocking this or anything, but I can't understand the physics of how it isn't impacting day 2 day use? The idea of a diff is to allow opposing wheels to travel at different speeds, such as when cornering. A welded diff would completely prevent this, either inducing wheel bouncing/slip and understeer. Or a complete resistance through the steering wheel to want to change direction.
- Thank you received: 305
15 Oct 2021 11:51 #239422
by sniper
sniper
Both front wheels are connected to each other and must be turning at the same speed, allowing no differential..... It has to cause tyre scrub when cornering....In 2wd the front diff is completely isolated from the transmission and road wheels, so the fact it is permanently locked makes no difference whatsoever to road driving.
sniper
- Thank you received: 468
15 Oct 2021 11:54 #239423
I'm guessing Busta has the front hubs disengaged ?
The following user(s) said Thank You: sniper, lookonimages
- Thank you received: 225
15 Oct 2021 12:25 #239426
by Busta
Yes the front vacuum hubs are disengaged when in 2wd. I have a separate switch so I can engage and disengage them as I please. Lots of people can't get their heads around it, but it's an incredibly capable setup for a daily driver. It's also a lot more manoeuvrable than a with a welded rear diff, but it does require some careful thought about when to use it.
- lookonimages
- Thank you received: 64
15 Oct 2021 12:53 #239427
by lookonimages
Replied by lookonimages on topic Re:Lockers
very interesting and thanks for sharing Busta.
Never crossed my mind, but then also admit never investigated diff locks as the gen 4 is very capable now with its allgrip traction control.
so yes I think it largely depends on a person's usage of jimny.
for the 2% overlanding / gravel roads usage I cannot see any reason to get diff locks ever. but the other guy that use his jimny 98% driving obstacles and doing rock crawling might have different opinion on diff locks.
15 Oct 2021 14:05 #239430
by 300bhpton
I guess the only downside here is. You can't run 4wd (driving the front wheels) without having the front diff locked. Which will impact steering/turning circle.
Thanks. Was completely forgetting about the freewheel hubs. Don't have such things on coil sprung Land Rovers.Yes the front vacuum hubs are disengaged when in 2wd. I have a separate switch so I can engage and disengage them as I please. Lots of people can't get their heads around it, but it's an incredibly capable setup for a daily driver. It's also a lot more manoeuvrable than a with a welded rear diff, but it does require some careful thought about when to use it.
Time to create page: 0.143 seconds
