BigJimnyMeet 2024
Towing a caravan
- Thank you received: 82
09 Sep 2021 11:34 #238387
by Dirtbird
Heavy Duty Transfer Box Brackets, 2-inch Black Raptor lift kit, caster adjusters, Rust removed and stich welded new sections. Galvanised Chassis. Body,Engine,transmission swap. Anti Rollbar Roll / Sway Bar / DAVES ARB disconnect kit.Osram Night Breaker Head light mod and white 501 led side lights.
Replied by Dirtbird on topic Towing a caravan
yeah belive ..........If a mechanic said it it must be true!
- Roger Fairclough
- Thank you received: 194
09 Sep 2021 11:48 #238388
by Roger Fairclough
Replied by Roger Fairclough on topic Towing a caravan
I converted my LC so that low range could be had in 2 wheel drive. Made slow tight manoeuvres a lot easier.
Roger
Roger
- Thank you received: 1761
09 Sep 2021 15:29 #238398
Replied by Lambert on topic Towing a caravan
This is the main reason I have manual hubs. 2wd low range with a automatic gives very controlled manoeuvres.
09 Sep 2021 15:44 #238399
by Dirtbird
I know a couple of guys who will off road in nothing only automatic gear boxes.
09 Sep 2021 16:07 #238401
In my opinion the beating that an auto dishes out to a manual off road is not funny. I will not be going back to manual.
- Thank you received: 71
10 Sep 2021 21:26 - 10 Sep 2021 21:28 #238445
by lightning
Replied by lightning on topic Towing a caravan
We've ordered the caravan (won't be delivered until early next year)
And see how the Jimny copes. lf it's no good, we'll use the Defender.
But hopefully it will be alright. The caravan is a Swift Basecamp 2.
lt's under 1,000 kg. We also ordered the AL-KO ATC anti snake system to be fitted.
We will do a towing course before taking delivery, as neither of us have towed anything more than a small trailer (and l was crap at reversing that)
Last edit: 10 Sep 2021 21:28 by lightning.
11 Sep 2021 03:33 #238448
If possible when you book your course try and confirm that you can learn/practice on a single axle trailer, most of the instructors I see round here are using tandem axle horse boxes or big box trailers which behave differently to single axles both forward and reversing. Your instructors should also be giving you the low down on hitch height and trailer attitude and loading. If If they are amenable then ask to use the Jimny with their trailer on their off highway facility it will help you judge how the Jimny will work with the swift before you are on the road. Good luck and congrats on your new arrival!
- Thank you received: 552
11 Sep 2021 15:50 #238478
by Scimike
Replied by Scimike on topic Towing a caravan
Congratulations on the future new arrival.
Just seen one in the flesh on the M5, look a nice size.
May I suggest some adjustable or better rear dampers if you think the Jimny will do it. They get a heck of a work out and my STD dampers (also old just in case it's simply worn out) proved inadequate.
Have fun.
Have fun.
Time to create page: 0.135 seconds
