BigJimnyMeet 2024
JB74 Rattling noise driving me crazy.
- jb74fan
- Visitor
13 Jul 2021 01:00 #236646
by jb74fan
Replied by jb74fan on topic JB74 Rattling noise driving me crazy.
I hope someone out there could share the the solution to this. O/P was right, it's driving me crazy too.
- epc2
- Visitor
07 Sep 2021 14:47 - 07 Sep 2021 14:48 #238319
by epc2
Replied by epc2 on topic JB74 Rattling noise driving me crazy.
I have not disappeared, for some reason I didn't have the notifications "on" , and didn't see the message until I received a PM from JB74fan.
Yes I resolved the issue.
I took it to my local Suzuki AD and they said it was common with the previous models and big tires , ( don't know if that's true , since I have no exp. with the previous model), they put some thick foam between the metal layers of the back door I guess to act as a dampening and checked the small foam squares of the wheel base mount, that helped a lot but then later on my own , I covered the entire part that goes under the plastic part with a deading material (Killmat)similar to Dynamat.
Hope that helps @jb74fan
Last edit: 07 Sep 2021 14:48 by epc2.
- Thank you received: 82
08 Sep 2021 10:44 #238340
by Dirtbird
Heavy Duty Transfer Box Brackets, 2-inch Black Raptor lift kit, caster adjusters, Rust removed and stich welded new sections. Galvanised Chassis. Body,Engine,transmission swap. Anti Rollbar Roll / Sway Bar / DAVES ARB disconnect kit.Osram Night Breaker Head light mod and white 501 led side lights.
Replied by Dirtbird on topic JB74 Rattling noise driving me crazy.
Was going to suggest using a long screwdriver to the ear but then thought "in a moving Jimny over a bad road " Screwdriver to the head .....not a great idea, but a doctors stethoscope might be a good idea.
- Groenewald
- Visitor
12 Sep 2021 05:56 #238501
by Groenewald
Replied by Groenewald on topic JB74 Rattling noise driving me crazy.
The source of all Jimny noises are electrical:
You need to swap your speakers and add a subwoofer, which will make them go away.
- Groenewald
- Visitor
12 Sep 2021 06:00 #238502
by Groenewald
Talking about rattles:
My new Gen4 had an irritating rattle in the front dash somewhere. It only showed up during some road conditions, and due to how quiet the rest of the car is, drove me crazy.
Finding the damn rattle was compounded by me being half deaf in one ear.
When I installed my subwoofer and new speakers, the guys obviously had to take the radio out and remove some dash panels.
In the process they inadvertently killed the rattle, so my sound upgrade actually DID fix my rattle.
12 Sep 2021 10:05 #238512
by Dirtbird
Thats a good one
- Geliboy13
- Visitor
16 Oct 2021 16:01 #239455
by Geliboy13
Replied by Geliboy13 on topic JB74 Rattling noise driving me crazy.
Not sure if this will also apply to your case but i also same problem with my JB74 2020 (all stock fitted with bf goodrich ko2). Rattling sounds when driving over bumpy roads and the sound seems to be coming from the rear door. I did everything (removed spare tire, dismantled the rear door panel and lubricated everything with WD40, sound foam and sound deadening all over) but with no avail.
But just today i found that the sound was not coming from the rear door but under the car. The culprit was just the wire or hose found over the right-rear suspension dampener. It was apparently hitting the chassis or frame of the car when driving over bumpy roads. I just bent it a bit since its attached to a thin metal frame so that it would not rattle or hit the frame. Problem solved. Try to look into this one might be the same as yours.
23 Mar 2023 11:40 - 23 Mar 2023 11:47 #248188
by Mahir
Replied by Mahir on topic JB74 Rattling noise driving me crazy.
Hello guys
i m new on this blog and i don’t find exactly how post a new problem so i found this way to tell you about my issue.
well, i have a vibrating sound in the back door of my jimny jb74. I tried to locate the exact place but couldn’t ….
I had that black wheel cover i thought it was the reason but the sound is still there after taking it off.
howewer, when i « punch » the back wheel i hear that annoying sound and trust me it drives me crazy. Sometimes i feel like the back door glass is vibrating, sometimes i feel there is something inside…
so i wanted to ask you guys if u have ever faced the same issue ?
what is the solution?
any guess ?
thanks for helping me out
any guess ?
Last edit: 23 Mar 2023 11:47 by Mahir.
- Thank you received: 478
23 Mar 2023 12:25 #248191
Replied by Soeley on topic JB74 Rattling noise driving me crazy.
Have you checked the tightness if the spare wheel nuts to make sure it is held securely? if they are tight, remove the spare wheel and check the wheel mount itself is secured properly.
- Roger Fairclough
- Thank you received: 194
24 Mar 2023 13:48 #248204
by Roger Fairclough
Replied by Roger Fairclough on topic JB74 Rattling noise driving me crazy.
On my LC, Toyota had fitted a small block of rubber that was fixed in such a way as to support the wheel at it's edge. This helped to prevent flexing of the back door, especially with my 33" spare wheel.
Roger
Roger
18 Aug 2023 08:47 - 18 Aug 2023 14:05 #250347
by Ak
Replied by Ak on topic JB74 Rattling noise driving me crazy.
i have the same issue. İ took off the plastic inner panel and then hold cables, parts inside with my left hand and keep punching the spare wheel with my other hand to locate the rattle source. But it never goes away. I think they might skip a part of the insulation between metal panels where they welded together. İ will try again hope i will find it. Emir
Last edit: 18 Aug 2023 14:05 by Ak.
18 Aug 2023 11:54 #250349
Replied by mlines on topic JB74 Rattling noise driving me crazy.
Have you tried thin rubber washers behind the spare wheel mount between the mount and the door? THere were some made at some point without 77151-82000 seal in place
Time to create page: 0.157 seconds
