BigJimnyMeet 2024
Re:Gen4 Workshop Manual
- Groenewald
- Visitor
22 Feb 2021 09:33 - 22 Feb 2021 09:33 #233090
by Groenewald
Replied by Groenewald on topic Gen4 Workshop Manual
It would be ideal to convert the CD based version to run from a MySQL database with a PHP/HTML front end.
Wonder what would happen if Suzuki were approached with this?
If red tape will be an issue, stuff that - We build our own service manual database. With all the guys on here and all the stuff they do it should not be an issue to get something populated pretty quickly.
- Searching Facilities
- Print / Export (if required)
- Granular add/edit permissions
- User groups, user account control and audit trails for logins, option to activate/deactivate user accounts
- Etc.....
Last edit: 22 Feb 2021 09:33 by Groenewald.
22 Feb 2021 10:33 #233092
Replied by mlines on topic Gen4 Workshop Manual
Just update the wiki on this website to create your own manual, just dont use copyright info
- Roger Fairclough
- Thank you received: 194
22 Feb 2021 18:00 #233107
by Roger Fairclough
Replied by Roger Fairclough on topic Re:Gen4 Workshop Manual
I have received two grovelling apologies from Suzuki GB. Basically I can have my money back and that's it.
So, unless someone who is far more computer literate than Viv or myself can come up with a practical way to con the info out of my, apparently, worthless cd, I will be be taking my money back whilst I give the parts dept . my dirtiest look.
Roger
Roger
22 Feb 2021 19:14 #233111
Replied by mlines on topic Re:Gen4 Workshop Manual
See here how to fix it....
- Thank you received: 479
22 Feb 2021 20:59 #233114
Replied by Soeley on topic Gen4 Workshop Manual
Thanks for this Martin,
Just copying the file over now, being a bit slow as I'm using my old DVD rom in a caddy with USB connection only. At first I couldn't copy the files over as the wwwroot folder was Read Only. I couldn't turn off the Read Only from the Properties, I had to go into Security settings on the folder first to give permissions to Users, then switch oof Read Only.
I hope it works for me
22 Feb 2021 21:59 #233117
All working, Thanks Martin.
And no need to get the external DVD-rom out every time I want to use it now
- Roger Fairclough
23 Feb 2021 09:46 #233127
by Roger Fairclough
Replied by Roger Fairclough on topic Gen4 Workshop Manual
Thank you Martin. I will hang onto the disc and Viv will do the business later.
Just as a matter of interest, how many forum members bought a disc?
Roger
Roger
23 Feb 2021 09:50 #233128
I dont know how many. I bought the early version and also subscribe to the online service. I use the dvd version for initial lookup and occasionally look at the subscription version to check for updates.
- Roger Fairclough
23 Feb 2021 11:54 #233134
by Roger Fairclough
Hi Martin...Its Viv (Rogers other half)
Have just tried to set this up and it all seemed to go very well.....until the last bit.
When I went to Internet Explorer and typed localhost/top.html I got the following error message
INET_E_RESOURCE_NOT_FOUND
I did check and the files were in the inetpub\wwwroot file.
Any suggestions please of what I should check.?
Also should all of the sub folders under the Internet Information Services folder be checked as I noticed that by default the FTP box remained clear.
Thank you
Viv
Thank you
Viv
23 Feb 2021 12:01 #233136
Hi Viv
What do you see if you type
http://localhost/iisstart.htm
23 Feb 2021 12:03 #233137
Or try
http://localhost/Top/TopPage.html
- Roger Fairclough
23 Feb 2021 12:12 #233138
by Roger Fairclough
I tried various ways without succes and as I could not then even connect to any websites I did a system restore to take things back to first thing this morning. All working and ready to try again now.
One question. I use McAfee Livesave and wondered if this could be causing any problems with the firewall?
Viv
Viv
Time to create page: 0.195 seconds
