Underseal ,Rust prevention. Is it worth it. ?
- Thank you received: 551
Thats just a bad day (funny) in the offiice, can happen to anyone with anything. Do it yourself, you know you want to!
Once drop a full can of "boil it youself" motorcycle chain grease in the kitchen.It promptly washed all over the floor and half way up the kitchen units before it solidified in a black grease line. The only clean patch was under my feet.
I had to jam the door to stop the wife entering the room and lie for 3 hours about why she could not come in whilst I removed most traces.
To this day she has no idea of just how bad it was
No longer used solid grease chain lube!!
- Thank you received: 368
Mike, I used to boil up Linklife on the kitchen hob for my motorbike chain, that was before me and the missus started living together, I then used an old camping gas stove, but the Linklife tin is too unstable, it fell off once, but was still semi hard, so enter my little portable gas range, it works great and is super stable and is useful to heat up anything in a tin..
images-na.ssl-images-amazon.com/images/I/41ZzvyRhpDL._AC_.jpg
My only incident with our cat (some time ago now, cat is long dead and buried in the back garden), I put some concrete down in the garage to cover the hole left by the gas board when they changed the meter. The cat stood in it while it was still wet (you can still see her foot prints) and then jumped up on to my sports car which was kept in the garage back then. The concrete marks came off the paint fairly easily, slightly harder from the soft top and the cats feet didn't seem to suffer at all. She was an outdoor cat, so didn't come in the house, just the garage and kitchen.
- Roger Fairclough
- Thank you received: 194
Roger
- Thank you received: 1759
are duckhams chain grease, them were the daysScimike wrote: Hahaha
What areas do they cover and what products do they use?
Thanks
- nogbad
- Visitor
- Thank you received: 70
The inside of the box sections seems to already have a coating of something and l assume the outer panels are galvanised.
However it obviously won't do any harm to do it, if it makes you feel better.
l've done some spraying of wax under ours, with a product that doesn't dry out like the wax oil l used to use on my Land Rover.
There were rust spots bubbling through the paintwork on mine and its not had a hard life in the short time I've had it.
Have a look under the jack.
l will, thank you for the advice.
l checked under the jack on our 2020 Jimny and there's some sort of bitumous coating, sprayed over in body colour, so unlikely that rust will come through there.
