Re:Re:Re:Eibach 25mm pro lift springs
media.carparts-cat.com/pdf/Einbau/192545/112/E3080003.PDF
- Thank you received: 1761
- Thank you received: 305
Wire diameter, free length and coil numbers are all pretty much irrelevant to the end user. Stance and performance are the benchmarks by which the vast majority of users will judge them.
The car sat higher, the car cornered better and it handled the off roading I do without complaint. What the specs say had no impact at all....
The Eibach name and +30mm were enough information for me to buy.... each to their own I suppose.....
sniper
- Jamin
- Visitor
I'm fitting the Eibach springs on Monday. Will report back.
- DavidWalsh
- Visitor
- Roger Fairclough
- Thank you received: 194
Roger
Roger Fairclough wrote: They are also linear rate instead of progressive. I fitted progressive rate springs to my TLC and got the best of both worlds.
Roger
Progressive springs are great for performance cars where you can have good cornering performance without losing plushness on the road, but for an off road vehicle they work back to front. For good road manners we want shorter travel, stiffer springs to control body roll and off road we want long travel soft springs to absorb big bumps and give good articulation. Progressive springs are soft for the first part of the travel making a top heavy car wobbly at low speeds, and then get progressively stiffer as you use more of the travel, killing articulation and off-road ride quality.
- Roger Fairclough
Roger
- Jamin
- Visitor
It drives better in all conditions. The springs provided quite a bit of lift, more than expected. The Jimny sits much higher than on the old stock springs. But the ride; it's better from a to z. Small bumps no longer jar the car, the springs ride over them like a car almost. The medium-high speed cornering and stability is miles better, much stiffer and less body roll.
Stock springs are both harsh on bumps and very soft and rolly. The Eibachs are the exact opposite.
Stock shocks are still retained at the moment, and I have no doubt the improvements will only increase with new shocks.
I recommend to anyone.
- Jamin
- Visitor
