Re:Tpms question
- zebraman
- Visitor
The tpms has two settings in the menu comfort and off-road or something. I might set it to the off-road and see what happens.
Worst come to worst I'll pop it back up a psi or two.
- Roger Fairclough
- Thank you received: 194
Roger
- Thank you received: 475
- CC Baxter
- Visitor
Anybody want to give it a go?
No you can't do that Roger, the system just doesn't check pressure it checks movement. If the tyres aren't rotating you won't get a reading. Chris
- GeorgeC
- Visitor
I argued for the tyres to be set at ISA and the TPMS calibrated accordingly.
This method would remove the need to adjust the pressures as the ambient temperature varied up or down. (same for altitude)
He did give me the Static Loaded Radius for their original Bridgestone 195 80 R 15 tyre, factory fitted to the Jimny, so the inflation pressures (altitudes) and load measurements can be compared or confirmed.
- Thank you received: 1759
Yes, there is a reset facility invoked by a door opening and closing sequence, but that currently just redetects the sensors You would have thought they could have made that "set" the warning level to 1 PSI below current tyre reading. That way you could have set the tyres to the pressure you want and coded the alert accordingly.Lambert wrote: Perhaps if they had coded the tpms to look for a difference in readings taken over 24 hours it would be a more effective system ie check every second compared with the figure from the same time 24 hours previous that way it's a relative measure and can warn of an issue but also allow for alternative terrain and tyre type pressure.
- CC Baxter
- Visitor
- Thank you received: 551
- CC Baxter
- Visitor
