Its Re:Re:Re:Turning the traction control off (Gen 4)
- Thank you received: 168
Messing about up the field last night. And in 2wd High. It seems the TCS or Dynamic Stability Control kept kicking in.
I tried pulling to a stop and hold in the TCS button for many seconds, it eventually beeps and on the binnacle display looks like it turns off the crash avoidance or something (the image of a car crashing into something). And the orange light with a vehicle and wiggly lines with 'off' comes up on the dash.
Great, but pull away and get some wheel spin and the orange lights flashes at you and it kills the throttle. And seems to rearm the system. ???
Not had a look in the manual yet. But how hard can it be too push a single button?
- Thank you received: 552
Found this in the wiki but its G3 related, looks like you are on the correct path. Did you try in 4WD-L?
good luck
Mike
Switching TC between ON and OFF states
TC can be turned OFF or ON manually by the driver in 4WD-L transmission mode by long pressing the ESC/TC button.
Long pressing means holding the button pressed in for at least a couple of seconds.
Unfortunately, the vehicle will give no sound nor audio indication that the TC has just been switched ON or OFF.
The only way to check if TC is ON or OFF in 4WD-L mode is to field-test it by applying strong sudden throttle in 1st low or 2nd low gear on a slippery surface.
When TC is ON, the operational indicator lamp on the instrument panel will blink intermittently as the vehicle is struggling for traction during acceleration.
When TC is OFF, that indicator lamp will not blink and the vehicle will have a classic behavior.
ESP OFF/ON: Brief press - disable/enable stability and traction control
ESP LONG PRESS when in 4WD LOW - Turns off Hill Descent control
4WD LOW - ESP is automatically turned off.
SPEED above 30MPH - ESP turns back on automatically even if disabled.
mlines wrote: For the Gen4
Thanks Martin.
I'll have a play this afternoon.
Although I'm not sure I can quite tally with the above. A brief press when in High 2wd seems to do nothing. No beeps, lights or visual aids to say it has done anything. A long press does do something.
In low the Hill Descent button turns this feature on/off. Not sure why you'd need to do the same with a long press of the ESP button?? Would seem a bit redundant. Unless when you turn ESP off in low it turns HDC off as well.
Bit annoying with it killing the throttle in high. Didn't seem to do it in 4wd High, but I wasn't getting the wheelspin, but I have a feeling the system may still interfere.
- Roger Fairclough
- Thank you received: 194
The traction control is mentioned in the handbook but noted as purely an automatic system which operates when traction is lost. If you were messing about then you probably activated the system automatically and it did what it was designed to do. There is no mention in the handbook of a method to turn it off.
Roger
- CC Baxter
- Visitor
I made a 555 timer module which in effect 'pushes' the button (8 seconds) everytime you turn the ignition on. Of course you get the beep to tell you what's going on everytime. If you push the button again you turn the system back on.
All I've done is to create default off as opposed to on. Hope this helps, Chris
Busta wrote: 30mph rules out 2nd gear skids. No fun! Had the same problem with the Range Rover. Tons of power but even with everything switched off the minute the fun starts the computer says no and switches everything back on again.
Unfortunately it's 30kph not mph. And it is wheel speed not vehicle speed. So ad soon as one wheel exceeds 30kph, the ESC kicks back in.
Turning the hill hold off is useful, but is more useful when you realise before the time that you need it off. I had the hill hold activate when reversing down a very steep slope. It was a very tippy feeling situation.
