BigJimnyMeet 2024
× A place for general chat about the Jimny. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Newbie with overheating jimny
  • rock botulin
  • Visitor
  • Visitor
21 Sep 2020 16:27 #228401 by rock botulin
Replied by rock botulin on topic Newbie with overheating jimny
Thanks ill try that next, fan could be suspect, rads arent to expensive either so may just change it anyway.
21 Sep 2020 20:56 - 21 Sep 2020 20:57 #228424 by DrRobin
If the heater cools the engine down then it suggests there is not enough water flowing through the radiator. Apart from what has already been mentioned it could be:
Head gasket - is the water dirty, the oil emulsified or one of the spark plugs very clean?
Water pump - is it turning correctly, is the belt slipping, can you turn the water pump b6 hand?
Thermostat not opening - not sure how you test this without taking it out.
If you are not loosing water, the oil is clean and the spark plugs normal, then it’s just use low flow. If the rad s clean and all of the pipes good then check the water pump after that it is most likely the thermostat.
Last edit: 21 Sep 2020 20:57 by DrRobin.
  • rock botulin
  • Visitor
  • Visitor
22 Sep 2020 08:36 #228434 by rock botulin
Thanks next chance i get ill check, got a water pump, may fit that at some point just to elliminate, are they easy to fit?
  • rock botulin
  • Visitor
  • Visitor
22 Sep 2020 08:38 #228435 by rock botulin
so far theres no sign its the head gasket , plugs are clean no mayonaise anywhere
  • rock botulin
  • Visitor
  • Visitor
22 Sep 2020 08:44 #228436 by rock botulin
by clean i mean dirty haha
Time to create page: 0.113 seconds
Powered by Kunena Forum
