Re:What tyre psi you running???
- Thank you received: 142
It has to be remembered that these tyres are part of the suspension settings and need a fairly soft ride unlike low profile tyres where the tyres are hard and the suspension is made accordingly.
Tyre pressures for vehicles are determined by manufacturers and are nothing to do with the pressures on the side of the tyres as that is just a max figure by the TYRE manufacturer for safety.
Yes garages just inflate them to 30/32 these days as most low profile tyres are around there.
Back in the day I was a tyre fitter and if the chart on the wall didn't have the car listed then we used to put in 24/25psi as that was the average back then.
I've had Halfords do it and also a Suzuki dealer lol
My wife went out after a tyre change and she said it was all over the road and when I checked they had only inflated them to 2.3 and 2.6 atmospheres instead of psi!!
- Thank you received: 1761
Grima wrote: Index - jimny chat - page20 - topic - tyre pressure for 215 75 15?
Lambert & Busta you both commented in this thread by B3HULK.
Have a read, It will back up what i said.
Grima, you can use whatever tyre pressures work for you! It's your car, do as you please. You will notice that Lambert and my advice is consistent because it is based on our own experience. Looking at that picture, BFGoodrich recommend anything from 19 to 30psi depending on speed and conditions, so it is not exactly definitive. A big difference that shouldn't be ignored is that they won't have actually driven a Jimny on those tyres in those conditions, but the people giving advice on here have.
- Roger Fairclough
- Thank you received: 194
Try this.
Drive the car onto a flat board. Mark the tyre across with a 50mm wide band of chalk. Push the car so that the chalked band rolls over the board. The chalk imprinted onto the board should be perfectly equal both in width and density.
Roger
- Roger Fairclough
Many years ago The Rover co. invited selected Range Rover drivers who p/e their RR for new ones at regular intervals to a lunch and factory tour at Lode Lane. Each driver was asked "have you ever locked the centre diff".
They all answered "pardon".
And that is why Rover fitted a viscous coupling.
Roger
I'm sorry if I'm labouring the point but there isn't one single pressure for one type and size of tyre to use in all situations and vehicle types. The weight of the vehicle, the type of ground it is covering and the speed at which it is doing so are all meaningful parameters for calculating the most suitable pressure for the conditions at hand.
- CC Baxter
- Visitor
Chris
No pressure or anything but it's an easy thing to understand!
- Phattaff
- Visitor
