Body lift Jimmy 04 1.3 help
- Scot The Sniper
- Senior Member
- Thank you received: 4
02 Aug 2020 22:38 #225998
by Scot The Sniper
Replied by Scot The Sniper on topic Body lift Jimmy 04 1.3 help
Are the steering bars the panhard rods?Steering bars are too long or need adjusted (if adjustable) im afraid.
A wheel alignment/tracking at a garage is always needed after altering this sort of stuff. Problem is finding one that will work on a modified car usually
Panhard rods are probably out as well (or have you covered that already?) If adjustable you need to set them so that the axle is central to the chassis. Measure off the chassis to the tyre and get it in the middle before worrying about the steering bars.
If you do take it to a garage for an alignment/tracking the steering 'toe-in' should be set at 2 degrees inwards (for a standard car, maybe less for huge tyres). The only other thing they can adjust is the panhards (if adjustable), but thats more for centering the axle to the car properly, but it does have an affect on the steering position so needs set before the steering bars
- Thank you received: 1627
03 Aug 2020 05:34 #226001
Replied by Lambert on topic Body lift Jimmy 04 1.3 help
No. The panhard connects the axle tubes to the chassis one for each axle.
- Thank you received: 919
03 Aug 2020 07:02 - 03 Aug 2020 07:08 #226002
Replied by X8GGY on topic Body lift Jimmy 04 1.3 help
Here you go Scot -
Yellow is the panhard rod, blue is the steering bar... both os these will need adjusting with a 3" lift like yours... think back to school days... as we’ve lifted the vehicle the short side of the righ-angled triangle as lengthened - so the hypothalamus has to lengthen accordingly, otherwise the axle is dragged over to the driver’s side
The wandering will be the castor being thrown out of geometry, so you'll need castor correcting offset bushes or replacement radius arms...
Oh, the fun of lifting Jimnys!
Last edit: 03 Aug 2020 07:08 by X8GGY.
03 Aug 2020 08:15 #226008
Hypotenuse is triangle. Hypothalamus is brains.
- Scot The Sniper
- Senior Member
03 Aug 2020 11:16 #226019
by Scot The Sniper
Thanks for the info guys
- Scot The Sniper
- Senior Member
26 Aug 2020 13:06 - 26 Aug 2020 13:08 #227365
by Scot The Sniper
ok back again after a break from the jimny its getting depressing now.
Ok as said before gonna need the adjustable steering bar and panhard rod adjustable.
Other things going threw my mind after doing all the other stuff to it its now lower in hight compared to the body lift which is disappointing prefered it higher with
the lift and now the tyres are hitting the arches. Someone give me the matches. Anyway can u put the spring spacers 1.5" back in the 3"lift springs to bring it a bit higher.
Also with the suspension lifted will I have to take the circlip of the driveshafts at the front to give it the extra movement.
And will I have to buy a panhard rod for the rear as well
Last edit: 26 Aug 2020 13:08 by Scot The Sniper.
- Thank you received: 120
26 Aug 2020 14:00 #227368
by 300bhpton
Replied by 300bhpton on topic Body lift Jimmy 04 1.3 help
Hope I don't come across as mean or grumpy.
But I assume you are modding purely for looks and not for off or on road performance?
If it is the later. You'd do yourself a world of favours by reading up, learning and understanding how the suspension works. And more importantly why it works that way.
Simply bolting crap on and hoping for the best while not having a clue to how any of it actually works, is a sure fired way of ending up with a heap. And there are so many badly modified 4x4's out there already, there really is no need for more of them.
Putting in the up front effort and learning how it all works, should pay dividends, as you'll know exactly what you need to do and why.
- Thank you received: 585
26 Aug 2020 14:37 #227371
Replied by jackonlyjack on topic Body lift Jimmy 04 1.3 help
Put 4x spring spacers back in to lift higher
DO not touch drive shafts this is not effected by any amount of lift
Front propshaft could benefit from a one inch spacer with a 4+ inch lift
27 Aug 2020 19:16 #227417
That's an old trick on the Vitara, not applicable to the Jimny
... Also with the suspension lifted will I have to take the circlip of the driveshafts at the front to give it the extra movement.
- Scot The Sniper
- Senior Member
28 Aug 2020 13:49 #227461
by Scot The Sniper
Hi mate I know what your saying and I totally agree only thing is I was only replacing the clutch and noticed a broken spring with it having a 3" lift I thought it was 3" springs already in there i did not know it was a body lift so all this is because of the broken spring. If I had known it was original springs it it i would of just put them in and left it as it was bit was on Facebook group and they advised to just get 3" springs for the rear and its just caused so many problems with me not having the knowledge to do this Iam a mechanic and have access to a ramp and my tools I can do the jobs easily but as you say if I knew I would not be pulling my hair out and of course I need to start somewhere and yes its just for looks and off road vermin control no proper offloading. So any advice is greatly appreciated. Scot
28 Aug 2020 14:22 #227463
So lets have a fresh start
What size tyres are fitted ?
- Scot The Sniper
- Senior Member
30 Aug 2020 12:17 #227546
by Scot The Sniper
Hi mate they are 235 75 15
Time to create page: 0.270 seconds
