BigJimnyMeet 2024
Body lift Jimmy 04 1.3 help
- Scot The Sniper
- Senior Member
- Thank you received: 4
14 Jun 2020 14:24 #223576
by Scot The Sniper
Body lift Jimmy 04 1.3 help was created by Scot The Sniper
Long story bought this jimny 3 years ago put clutch in last week on putting it back in noticed ot had a broken front spring. The guy I bought it from said it had a 3" lift ok so went and bought 2 3" front springs fitted them now it looks like a monster truck at the front. Took advice was told keep the 3" springs on and put 3" springs on the rear but remove the body lift that the last owner must of done. Removed all the plastic blocks from the body to lower it back down but I think fitting these blocks the must of got extended body bolts I was told take the lift off and just bolt it back up there should not be a problem well there is a massive one the 2 rubber bushes one goes above the chassis and one below there is a about a 3" gap now I'm sure this is the problem where will I get the proper ones to fit on my jimny please.
Scot .jpg[/attachment]
- Thank you received: 923
14 Jun 2020 14:38 #223577
Replied by X8GGY on topic Body lift Jimmy 04 1.3 help
In your photo the "sleeve bolt" is still through the lower body mount. If you take that out the bush will then fit up under and against the chassis body mounting cup...
You then need to use nuts to attach the rubber bush and washer under the chassis body mounting cup... the two at the front of the doors and the two right at the back are 10mm metric FINE (1.25mm pitch) thread and the two behind the doors are 12mm metric FINE thread too...
I have some I can post to you if you can't source them
Dave
Dave
- Thank you received: 1761
14 Jun 2020 14:39 #223578
Replied by Lambert on topic Body lift Jimmy 04 1.3 help
Looking at the picture that bottom bolt thingy is threaded onto the body studs in place of a normal flange nut?
14 Jun 2020 14:40 #223579
14 Jun 2020 14:43 #223580
Hang on... this rings a bell? Was I speaking to you on eBay? Dave (ZookBOB)
14 Jun 2020 14:48 #223581
You'll probably find the bolts under the headlights are too long now too?
14 Jun 2020 15:07 #223583
14 Jun 2020 15:26 #223584
Here you go!
Metric fine (the thread that Suzuki use just to be awkward!)
Two bolts to go under the headlights into the chassis cupped mountings as yours will now be too long
Four 10mm nyloc locking nuts for the small body mounting studs, and...
Two 12mm nyloc locking nuts for the small body mounting studs
And below is my paypal email address, a tenner should cover the parts and postage
Hope that helps!
Dave
Hope that helps!
Dave
- Scot The Sniper
- Senior Member
14 Jun 2020 16:17 #223585
by Scot The Sniper
Replied by Scot The Sniper on topic Body lift Jimmy 04 1.3 help
Dave that would be absolutly magic give me a price plz mate
14 Jun 2020 17:06 #223589
Just a tenner will do, to cover the parts and postage...
Dave
Dave
- Scot The Sniper
- Senior Member
14 Jun 2020 17:32 #223591
by Scot The Sniper
That's no me on ebay mate I have just found this out today.
- Scot The Sniper
- Senior Member
14 Jun 2020 18:04 - 14 Jun 2020 18:08 #223592
by Scot The Sniper
Its saying pending grrr hope I have wrote down the email properly. Was it This email address is being protected from spambots. You need JavaScript enabled to view it. or was it Capitol S
Last edit: 14 Jun 2020 18:08 by Scot The Sniper. Reason: Adding to discription
