Automatic gearbox advice..
- Jcg1694
- Visitor
Wanting some advice on my Jimny.. 2015 Automatic.. can anyone tell me what RPM they're revving at when running 60-70mph down motorways? I've been told these have an overdrive but not sure whether mines engaging correctly or not! Im revving at around 4k at 60mph.. and 4.5k at 70mph.. any advice or reply is appreciated. Thanks!
- Thank you received: 225
At the risk of stating the obvious, the JB43 auto shift lever has 2 positions for drive. In the "D - 3" position, if you move the lever a little to the right, the transmission will only shift from 1st to 3rd. If you have it solid to the left (still in D - 3), it will shift through all 4 gears.
- Jcg1694
- Visitor
- Thank you received: 1759
With a code, you may find one of theses is at fault:
- Jcg1694
- Visitor
- Jcg1694
- Visitor
- Jcg1694
- Visitor
Output shaft speed sensor?
Not sure if your 188700 is the same code
Jcg1694 wrote: I was thinking that myself in all honesty, this is the first jimny I've ever drove so wasn't expecting it to be a motorway kind of car, and didn't know anyone who has owned an automatic one either to ask if it was running as it should
Yeah, I'm not convinced that you have a problem. I remember driving a 1999 standard manual one to Wales from Essex years ago, which I later owned for a short while and that revved so highly in 5th we only did short bursts at 70 mph. That was a manual.
They're also driving the last iteration of the Gen 3.
Is there a third gear holding gear for you to force it to stay in 3rd and see what the revs are at 70?
