Wheel/tyre rotation and TPMS (Gen4)
- Eacg14
- Visitor
Right, Bob?
- Bill Portland
- Thank you received: 77
Eacg14 wrote: Ignition to "ON", press in and hold the button/dial thing on the bottom right of the cluster until the menu pops up. Then you can scroll through the menu and find TPMS reset.
Right, Bob?
Hi thanks, but there's no reset there, just the ability to view the pressures, if the system is working. If it's not working, you just see 4 "--".
You can change from "comfort" to "load" mode, but that's all.
The menu options differ from country to country.
Can I recommend stating the age, model and country in any reply for clarity.
- Bill Portland
GeorgeC wrote:
See Pages 3-69,70,71 in the PDF Manual.Eacg14 wrote: Ignition to "ON", press in and hold the button/dial thing on the bottom right of the cluster until the menu pops up.
Right, Bob?
There is a scanable PDF here: www.facebook.com/groups/2184373498316066/files/
Thanks again George. The manual is a bit misleading in that it states that you have to have a dealer set or reset the system. It is also wrong when it says that the spare doesn't have a sensor. It does - at least mine does, and also those that have had no problems when changing wheels must have one in their spares too.
The good news is that, at the 3rd attempt, I went for another drive and after about a mile the warning disappeared and the system is working fine again, including the spare (which is not the spare anymore). Martin was right, it seems a bit flakey but it will auto reset given enough opportunities. I blame 5g!
Glad its working. I think that the flakiness of the auto is why the UK Dealer manual puts emphasis on the manual reset.
There is a list of reasons in the manual as to why the TPMS system may fail to learn or generally miss read the sensors.
Your joke about 5G is close to the mark. TPMS works on the ISM (Industrial Medical Scientific) frequency of 433Mhz which is bang in the middle of the Military (primary user) and Amateur (secondary user) radio band (UK allocations). Therefore transmissions from these will interfere. The specific ISM frequency is used by all sorts of low power devices such as remote keys for cars, indeed "Remote Keys" is listed as a reason TPMS readings may fail, along with RF shielding (the car is a tin box with the wheels on the outside).
I learnt to not trust it when I lowered the pressures on our Jimny to the proper pressure for our mud tyres. I got the expected alert which would not then clear when the tyre pressures were restored to normal. It took a long journey of over an hour to settle back down. This is probably due to the sensors only running in "fast mode" for the first 10 minutes of a journey (fast is a reading once every 16 seconds) after this it drops to a quarter of this (reading once every 64 seconds - "active mode"). It is easier to miss a reading that occurs only once per minute.
- Thank you received: 95
Right, Bob?
Correct - that's precisely what I have and do. And there was me thinking that this technology existed to make life easier for us all. At least Bill now seems to have a solution and hopefully his blood pressure has lowered.
Sometimes I think - What was wrong with just manually checking your tyre pressures every few weeks?
- Thank you received: 551
I have never owned a vehicle with TPMS and your are not selling it to me as a feature I would want.
- Thank you received: 96
- CC Baxter
- Visitor
You couldn't be more wrong Mike, TPMS is a valuable training aid for new drivers teaching them that regular tyre inspection is totally unnecessary. After all, whoever heard of a tyre related road accident. Car manufacturers have thoughtfully removed all these concerns by providing a truly foolproof solution.
Chris.
- Paulei
- Visitor
Right, Bob?
I try to look but an access is requested, while I do not have a Facebook account, can You let help me to get the file?
spooftpms.com/?fdx_switcher=true
Scimike wrote: Are Suzuki deliberately making a simple task difficult or are all TPMS equipped vehicles this involved?
I have had a couple of cars fitted with TPMS and as an electronics design colleague described it to me "It's another piece of technology looking for a home"! The marketing guru's have bought into it as another 'chargeable technology feature' to impose on customers. It delivers negligible benefits to owners and increases the opportunities for further profits in the future.
