Wheel/tyre rotation and TPMS (Gen4)
- Bill Portland
- Thank you received: 77
Lambert wrote: You're forgetting that modern cars are not designed for the owner to maintain but instead to generate work for the service department.
Very true Lambert, but both the dealers I spoke to (pre lockdown) weren't interested
- Thank you received: 95
- Grima
- Visitor
- Thank you received: 1755
Suzuki dealers are evidently a very hit and miss bunch. My two local ones are not so bad but having ventured further afield they seem to be very patchy. In my Subaru days though every time I had a dealer interaction I was always treated as a valuable customer.
- Bill Portland
It must have been your posts that I'd read and thanks for your comments above.
Do you think I've not done something I should've?
Maybe I was too impatient and should have waited longer? It was probably at leat 1/2 hour between test drives, maybe it took that long for the 1st change to register, and needed longer for the 2nd to register? That could explain why the spare seemed to be OK during the 2nd test run.
@Bob1050 - you mentioned "reset" in your post above, was that something physical that you did?
The valve stem on the spare looks identical to the other 4 valves. Is that an indicator that it has a sensor?
- Grima
- Visitor
The overall limit is 4 wheels which is internally set, therefore regardless of whether the spare is fitted with the sensor or not, you can only see the four wheels on the car.
Whenever a wheel is changed, moved around etc. The most reliable way of resetting the system is the manual way.
That is what I described. Force the system into learn mode and then walk around the car triggering the sensors. Because you have walked in a set pattern there is no further learning period and everything is set. This is the way recommended by Suzuki and the one dealers should do as it means the car owner sees any issues cleared when the car is taken away.
The second is the Automatic Way, this is what Bill was trying although the Suzuki guide recommends the manual method.. The Auto method where you simply let the car learn the tyres and sensors it has fitted automatically. This can take a while to settle down and can be erratic.
As documented elsewhere the automatic method is:
1. Turn off the ignition for AT LEAST 20 MINUTES.
2. Drive ABOVE 16MPH for AT LEAST 10 MINUTES. The system will relearn all the tyre IDs and their location.
The problem with the auto method is that if the sequence is interrupted it has to start again. Suzuki say that that includes the 20 minute ignition off. So it seems to be an unreliable method, although I believe that if you just keep on driving it will sort itself out.
(PS. In answer to my own question, I now know that if you have manually erased the codes but then not completed the sequence it will still complain and will relearn what it has fitted.)
- Paulei
- Visitor
Take a look to this:
www.bigjimny.com/index.php/forum/7-jimny...imny-and-tpms#206430
- Bill Portland
Started from scratch and moved all 5 wheels around the car.
Went for a drive. After about 10 minutes without dropping below 25mph the dash lit up with the "TPMS Service" warning and a couple of amber warning lights. Drove on for about 5 minutes to find somewhere to stop.
Stopped with engine and ignition off for 25 minutes.
Started up again and TPMS warning still on. Drove for another 10 minutes without stopping.
No difference, dashboard still lit up with amber warnings.
I guess I'm gonna have to make a trip to the dealer when they're open and have them reset the system.
Seems odd that some people can do it without any issue.
Getting punctures and subsequently changing wheels around on a 4x4 must be quite common. Why is it so difficult!
- Bill Portland
Reset option? What reset option?
