New wheels & tyres needed help please
19 Apr 2020 08:18 #221260
by MrPunch
Replied by MrPunch on topic New wheels & tyres needed help please
Can I add the example picture I sent Is exactly that an example we could never afford such luxury......it would need to be that sort of look on a Budget thanks
- Thank you received: 1
21 Apr 2020 07:38 #221336
by Brucester
Replied by Brucester on topic New wheels & tyres needed help please
Same sort of scenario MrPunch. Her 15"steels have had so much Hammerite over the years from the previous owners and as she needs new tyres i thought go to 16" steels / alloys from the standard 15". I also like the chunky tyres for all the wrong reasons as we don't go off-road anyway, but the problem is trying to find a wheel & tyre plus chunky tread combination.
For MrPunch and also for jackonlyjack to confirm if you can;
The rims I am hopefully getting are DOTZ Dakar 7.00x16 5x139.70 ET0.00 from www.oponeo.co.uk
With either 205/65/16 or preferably 225/60/16 tyres., (subject to chunkiness). I will search later for the BF Goodridge All Terrain TA you posted, also one of my neighbours has Malatesta Kobra Trac NT but they are on 15" steels.
The 205/65/16 give 9.78mph reading at 30mph and 59.56mph at 60mph with a ride height gain / arch gap loss of 2.45mm.
The preferred 225/60/16 tyres give 29.63mph reading at 30mph and 59.25mph at 60mph.
The above worked out on site called www.willtheyfit.com
All of which is to say my knowledge is based purely on the help of jackonlyjack, (that's not to say blame him if anything goes wrong, simply that i learned from him), and before i buy anything i'sll still confirm on here and again with the steel / alloy suppliers and then the tyre suppliers.
Hope that helps. Oh and welcome to the club.
21 Apr 2020 12:58 #221350
by Brucester
I've now found 16″ x 7″ Tuff Torque 8 Spoke Steel Black ET0 on 4x4tyres.co.uk They do wheel & tyre packages, however, rather than going for a chunky look, i have opted to go for Cooper tyres from Formula 1 as they're made in the UK and they come with accidental damage warranty, including punctures repaired foc or a new tyre if it can't be repaired, subject to a percentage for tread wear etc.
22 Apr 2020 11:57 #221369
by MrPunch
Hi Brucester,
How are you getting on with this? I am in the exact boat probably way behind the knowledge you have gained here.
Please can you help me a bit I bought the wife a 59plate JLS Plus and she would like some chunkier tyres but she doesn’t want them to be wider than the body too much. Mentioned getting the alloys that are poor re-coated and buy tyres or is the way forward by a full set not sure how to put pictures on here to give an example of the type of effect she would like .
This is what’s on currently:
Front
Back
This what Tyres I have purchased:
I’ll post a pic when I get it back.]
Front
Back
22 Apr 2020 12:12 #221370
by MrPunch
Hi Brucester,
Struggling a little bit to understand how to post on the site I’m not very good at this….Anyway what I wanted to say was:
I have made a decision to have the original Alloys Powder coated I have also Bought 4new Insta Turbos as per the picture.
It gets away from will they fit lifting it lowering it and I suppose will get the look my good lady wants.
Another thing as for going off-road no chance the closest will be when it rains & then that’s a huge decision to drive for her…..The mpg & wear also not an issue doesn’t do more than a 1000miles a year.
Now I’m Struggling to find a new set of Plastic Centre Caps strange size they just pull off though I want a new set to go with the newly painted wheels…
22 Apr 2020 12:15 #221371
by MrPunch
Fronts are being Painted as they cant go in the acid bath so that’s fine its the rears that are causing me an issue now....I’m going to ask elsewhere on here Good luck with your Project
- Thank you received: 585
22 Apr 2020 12:42 #221373
Can't you just paint your originals Buzzweld do a plastic in one paint (PIO)
Replied by jackonlyjack on topic New wheels & tyres needed help please
22 Apr 2020 13:00 #221375
by MrPunch
HI jackonlyjack,
One of them has a slice right along it and they are sort of perished dont think they would spray up very well they are like a soft plastic not quite rubber part.
Sorry Jack what does PIO mean ?
22 Apr 2020 13:06 #221376
PIO is what buzzweld use as an abbreviation for plastic in one
send this guy a PM he may have some spare
www.bigjimny.com/index.php/forum/profile/1482-j999pre
The following user(s) said Thank You: MrPunch
22 Apr 2020 13:10 #221377
by MrPunch
Thanks Jack I appreciate your help
23 Apr 2020 16:35 #221428
by MrPunch
23 Apr 2020 16:52 #221429
Looks well
Time to create page: 0.417 seconds
