BigJimnyMeet 2024
× A place for general chat about the Jimny. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Help needed - Jimnybits radius arm guards??
  • Andy2640
  • Visitor
  • Visitor
02 Apr 2020 17:50 - 02 Apr 2020 17:52 #220596 by Andy2640
Hi everyone! Hope you are well, or at least content in these surreal times.
Ive got some arm guards here, but im worried about fitting them, becuase of the possibilty of the arms themselves moving once the bolt is taken out. Worried i wont get them aligned again once they move.
I dont have axle stands, only x2 wheels ramps and x2 jacks.
Do i need to place the car on stands, or is it alright to just use a jack under the arm itself.
Earlier i did a bit of a test, where i jacked under the arm to take the weight, and just wiggled the bolt in and out (without going the full hog and pulling it out) and it was moving quite freely.
Scratch noggin time.
Last edit: 02 Apr 2020 17:52 by Andy2640.
02 Apr 2020 18:06 #220598 by Scimike
Hi Andy,
If things move you can use a ratchet strap around the axle tube move things forward / rearward and a jack under the arm for up / down, it's an old trick when aligning the cart springs on old Land Rovers. Please note this has nothing to do with supporting the vehicle, just movement of the arm.
As an aside, do you need to support the vehicle when you remove the bolt? Just chock all four wheels to prevent movement of the axles and do one guard at a time. I can't think why you would need any support or need to lift on a jack. Please correct my ignorance if I am wrong.
Interested in the replies also.
Mike
The following user(s) said Thank You: Andy2640
  • Lambert's Avatar
02 Apr 2020 18:19 #220600 by Lambert
Yes you chock all the wheels front and back and let the vehicle support itself on its wheels. Obviously you have to be on the flat and level as best as possible that way the axles can't move relatively. Quite simple and as Mike says a ratchet strap can pull or push as needed.
  • Andy2640
  • Visitor
  • Visitor
02 Apr 2020 19:15 #220607 by Andy2640
Replied by Andy2640 on topic Help needed - Jimnybits radius arm guards??
Thats just what i wanted to hear. Thank you so much chaps! :) :) :) :)
02 Apr 2020 21:20 #220609 by Johnniehec
Yes as level as you can, chock all wheels front and back and do one at a time. You can put a big screwdriver in from the other side as you pull the bolt out.
03 Apr 2020 08:19 - 03 Apr 2020 08:20 #220617 by Bosanek
Don't forget to apply a thin layer of a thread anti seize compound on the bolts before reinstalling them.
The mechanic who had installed the radius arm guards to mine did not do that, and I could not remove the bolts only two years later without damaging the radius arm bushes. I had to sell the car with the radius guard arms on it, and then buy a new set for the new Jimny .....
Last edit: 03 Apr 2020 08:20 by Bosanek.
  • Andy2640
  • Visitor
  • Visitor
03 Apr 2020 10:35 #220619 by Andy2640
Bosanek wrote: Don't forget to apply a thin layer of a thread anti seize compound on the bolts before reinstalling them.
This forum is such a valuable resourse! Never have a met such warm, welcoming and knowledgable bunch ofnpeople, all with different skillsets all in one place.
First arm complete, not a nano measuremnt of movement, and bolt has had grease stuff applied. Going great, thanks to you lot.
Dont know about you, but the lockdown thingy is becoming very surreal, our neighbours look very mean and upset today. I did bang my sourcepan last night though, that was fun, and creates solidarity, enough to delay the zombie canabalism for a few more weeks.
Joking aside (kinda) i just wanted to thank you all.
I'll be back in 30 mins when it goes nipples up and berate you all for the lousy advice :laugh: :laugh: :laugh:
03 Apr 2020 13:05 #220626 by Scimike
Hope it's all going well Andy.
You have inspired me to fit mine.
I have some new old stock ORA guards that have been gathering dust. I don't actually need them, but I like the idea of having them (just in case), but was too lazy to fit them, so they have gathered dust for a year.
Put them in the "strange times" things to do list, just under fit towel rail (also covered in dust ) this first to keep my better half happy.
Mike
  • Andy2640
  • Visitor
  • Visitor
03 Apr 2020 14:10 #220628 by Andy2640
Good on ye mate! Soeley inspired me to do mine, or gadget, i always get them mixed up lol.
X2 rear guards complete. But.... im worried about the front passenger side, the bolt feels very tight, as if when i pull it out the arm is gonna shift.
I know i could use a ratchet strap, but still very anxious about removing the bolt.
Is there a reason why the front is any more unstable? Could it be cus it has a pivot for steering?
03 Apr 2020 15:36 - 03 Apr 2020 15:37 #220632 by Scimike
I can't think why the front bolt would be tight compared to the rear. I guess it's possible, if you do a lot of pre-parking steering work at low speeds, that the front tyres are exerting a slight load. With the wheels straight ahead rock the vehicle backwards / forwards to settle it all and try again?
Other than that just go for it and deal with any movement should it happen. Sods law states you will do three fine, the forth will be a real fight.
Good luck.
Mike
Last edit: 03 Apr 2020 15:37 by Scimike.
03 Apr 2020 16:13 #220636 by Soeley
Scimike wrote: I can't think why the front bolt would be tight compared to the rear. I guess it's possible, if you do a lot of pre-parking steering work at low speeds, that the front tyres are exerting a slight load. With the wheels straight ahead rock the vehicle backwards / forwards to settle it all and try again?
Good luck.
Mike
LOL, that is how exactly mine was first three a doddle, last one move back about an inch.
03 Apr 2020 16:31 #220638 by Dunders
You've inspired me to do mine as well. Bought a set off JimnyBits and was wondering the same thing. What torque did you bolt it down to?
Time to create page: 0.168 seconds
Powered by Kunena Forum
