BigJimnyMeet 2024
Snorkel template!
- Thank you received: 551
28 Mar 2020 12:23 #220358
by Scimike
Replied by Scimike on topic Snorkel template!
Hi Riccy,
Don't suppose you would consider posting the template to me, I will cover the postage cost?
I don't want a snorkel on my Jimny, but as I could have a go at turning it into a printable PDF and put it in the wiki for those that do. Sort of like a print at home template on A4 and sellotape together if it works.
No problem if you don't want to venture out or just don't want to, and I am in no rush if you do.
Mike
Mike
28 Mar 2020 16:23 #220359
Replied by Riccy on topic Snorkel template!
Hi Mike,
yes of course, PM me your address and I will get it sent Monday (not like ive a lot else to do atm).
You are in a good position to try the template against your original wing to see where it goes.
Riccy
Riccy
The following user(s) said Thank You: Scimike
28 Mar 2020 16:30 #220360
by Scimike
Thanks Riccy,
It gives me something to do also!
Hopefully in the future if needed it can be downloaded.
I'll send you a PM.
Mike
I'll send you a PM.
Mike
- Thank you received: 332
28 Mar 2020 21:59 #220384
Replied by yakuza on topic Snorkel template!
Made my own template today and it was partly successful. My snorkel is mounted, but I guess it should have been a cm or so more fwd.
No problem with the bolts but where to start with the big hole was a bit hit and miss.
Drilled the bolt holes from my own template in one go and they all fit but had to expand them all fwd after drilling.
So a template or at least some measurements for the center of the big hole would help greatly.
- Thank you received: 651
28 Mar 2020 22:03 #220385
Replied by jackonlyjack on topic Snorkel template!
No eBay APP ID and/or Cert ID defined in Kunena configurationOne of these is your friend when fitting a snorkel
29 Mar 2020 10:09 - 29 Mar 2020 10:13 #220396
I got one of these:
drill bithttps://productimages.biltema.com/v1/Image/article/xxlarge/20542/2
also a reciprocating saw and a step drill:
great drill for sheet steel
Sadly i can't blame the tools for the bad measurments and lack of a template.
Last edit: 29 Mar 2020 10:13 by yakuza.
- Keirravn
- Visitor
03 Apr 2020 07:25 #220616
by Keirravn
Replied by Keirravn on topic Re:Snorkel template!
Great timing for this thread, I'm just about to fit one without a template myself!
Sent from my CPH1951 using Tapatalk
- Keirravn
- Visitor
03 Apr 2020 18:27 #220646
by Keirravn
Got mines on with a homemade template. Not as bad as I thought it might be - didn't take long in the end
03 Apr 2020 20:08 - 03 Apr 2020 20:14 #220657
By the way, Riccys template on page one will not do for a TJM airtec snorkel, it is a different bolt pattern. Mine had 6 pcs 10-12mm holes for M8 bolts and 81mm big hole.
Last edit: 03 Apr 2020 20:14 by yakuza.
- Thank you received: 305
04 Apr 2020 10:54 - 04 Apr 2020 10:54 #220674
by sniper
Replied by sniper on topic Snorkel template!
Last edit: 04 Apr 2020 10:54 by sniper.
Time to create page: 0.147 seconds
