BigJimnyMeet 2024
Snorkel template!
- Evzlid
- Visitor
25 Mar 2020 17:50 - 25 Mar 2020 17:52 #220261
by Evzlid
Snorkel template! was created by Evzlid
Hi guys, I’m new to the forum but have used it many times to help on my jimmy! Thanks for all your great advice throughout the forum! In these lockdown times I was going to try and fit my snorkel I have had for years but I don’t have a template! Does anyone have a copy of one or any advice for me!
Thanks in advance!
Andy
Thanks in advance!
Andy
Last edit: 25 Mar 2020 17:52 by Evzlid.
- Thank you received: 551
25 Mar 2020 17:56 #220262
by Scimike
Replied by Scimike on topic Snorkel template!
Can't help with template, but I assume different snorkels exist, so which make do you have?
This may help others or it's a daft question on my part.
Only advice is measure many times and cut once, especially as the template is unknown until it's fitted.
Good luck
Mike
Good luck
Mike
- Evzlid
- Visitor
25 Mar 2020 18:04 #220263
by Evzlid
Replied by Evzlid on topic Snorkel template!
Hi mike, thanks for the reply! It’s the long style type with Jimny on it! I’m mostly unsure of the position it would go! The pipe that connects to the air filter is angled making it a bit harder!
Thanks again!
Andy
Thanks again!
Andy
- Visitor
25 Mar 2020 22:37 #220269
Replied by Daniel30 on topic Snorkel template!
Haven't got the template any more, but I don't know if pictures of mine with measurements would be any good?
Sounds like it's the same as mine.
And welcome to the forum
- Thank you received: 329
25 Mar 2020 23:55 - 25 Mar 2020 23:55 #220270
Replied by yakuza on topic Snorkel template!
How wierd and strange. Was in my garage earlier tonight and looked at my used tjm airtec snorkle, and googled a bit to try to find a template. Now a few hours later it is the freshest topic. Coincidence!
Anyways I only found the install description for the gen4 snorkel on my small phone screen, will look harder tomorrow for the gen3.
This is also a good idea:
www.bigjimny.com/index.php/forum/6-jimny...rkel-template#167581
Last edit: 25 Mar 2020 23:55 by yakuza.
- Max Headroom
- Banned
- Thank you received: 217
26 Mar 2020 06:37 - 26 Mar 2020 06:37 #220272
by Max Headroom
Replied by Max Headroom on topic Snorkel template!
A BIGJimny Welcome from the Cotswold Hills, Evzlid!
I'm with Scimike on this; measure umpteen times and cut once. Alas I can't help with a template either.
There are some other Jimny rescources you could try such as Facecrook or see if there are any templates to download from other companies although that won't neccessarily be helpful and could ultimately cause a mistake. Other than that it's probably going to be a lot of maths and dead-reckoning to get the hole right.
Did you ever have the template and mislaid it? If so - get searching! Good luck
Last edit: 26 Mar 2020 06:37 by Max Headroom.
- Visitor
26 Mar 2020 09:25 #220277
Think it will be a case of making you own by covering the reverse of the snorkel with paper and trimming it out
26 Mar 2020 12:25 #220278
by Scimike
I think Daniel30 is correct. I've had a Google (stuck at home) and not found any requests for templates that have been successful.
So making your own using the snorkel as the guide is probably the best option. Start with getting the large hole in the correct location and allow for a bit of adjustment, then use this as the marker for the fixing holes you have marked on your template. Take your time, measure twice, cut once and you will be fine. Paint the cut holes to prevent rust and you are snorkeling before you know it.
26 Mar 2020 16:46 #220283
Replied by Riccy on topic Snorkel template!
Im sure I have a couple of these templates, Im off tomorrow so will dig it out and make a decent drawing for everyone
- Evzlid
- Visitor
26 Mar 2020 17:44 #220288
by Evzlid
Thank you so much everyone for your reply’s! Great to finally be a member of this site! Riccy it would be amazing if you could do that and I will take everyone else’s advise and measure twice and drill once! Thanks again folks!
Andy
Andy
- Evzlid
- Visitor
26 Mar 2020 17:46 #220289
by Evzlid
Thanks mate! I’m sure that would be a great help if it’s not to much trouble! Thanks for the welcome!
Andy
Andy
27 Mar 2020 16:29 #220327
Here you go...
Its beyond my skills to create a CAD file of this, but maybe the measurements ive put on are enough to work from ?
Riccy
Riccy
Time to create page: 0.143 seconds
