BigJimnyMeet 2024
× A place for general chat about the Jimny. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Jimny drop pitman arm
29 Jan 2020 16:17 #217809 by Jefferies
Hi guys,
I'm after a drop pitman arm for my jimny as i think i'm going to have a clearance issue between my sump (isuzu engine conversion) and drag link. I've scoured the internet and not found anything specifically for a Jimny. Raptor4x4 do one for an SJ (i believe the SJ has fewer splines) but i'm not getting anywhere in talking to them about the possibility of doing one suitable for a Jimny. I saw an old thread that suggested Jimnybits used to supply them but of course they don't any longer (i'm awaiting a reply from them). So basically i was hoping somebody would either have one they no longer need or could point me in the direction of a viable alternative. I have considered designing one and having it made but it'll inevitably end up costing £££.
Cheers
29 Jan 2020 16:30 #217810 by X8GGY
Replied by X8GGY on topic Jimny drop pitman arm
I've got a vague memory that Rhino-Ray does them?
I had a Zanfi one, but they were rather expensive!
www.zmode.it/prodotto/pitman-arm-per-idroguida-jimny-benzina/
165 Euros! Ouch! :ohmy:
29 Jan 2020 17:45 #217815 by Jefferies
Replied by Jefferies on topic Jimny drop pitman arm
Ah cheers i'll give him a shout
Yeah the Zanfi one looks nice but is on the expensive side
30 Jan 2020 21:59 #217870 by jackonlyjack
31 Jan 2020 07:17 #217880 by yakuza
Replied by yakuza on topic Jimny drop pitman arm
"Following"
one day I will put a Jimny steering box in my SJ and then I would need a pitman arm with more drop than the jimny arm..
Would not consider making it myself even though I have acces to a wide range of machining capacity through my work.. coned splines...
31 Jan 2020 09:55 #217886 by Keithy
Replied by Keithy on topic Jimny drop pitman arm
I drew this up to straighten the draglink on mine......decided to make new axles instead.
  • Old Blind Dog
  • Visitor
  • Visitor
02 Feb 2020 03:28 #217957 by Old Blind Dog
Replied by Old Blind Dog on topic Jimny drop pitman arm
Jimny steering box is quite weak - seen broken shafts a lot, better flatten knuckle arm. There's the cheapest way - use mersedes 124-126 arms. Left for right hand Jimny and vice versa.
03 Feb 2020 14:48 #218018 by Jefferies
Got in touch with rhino ray and he does a modified drop arm made from two standard arms welded together. He quoted £140ish so if all else fails i could go down this route.
03 Feb 2020 18:26 #218028 by yakuza
I do not recommend anyone to try this "at home". Even if it is cast steel or wrought steel be very careful to use the correct heat treatment both before and after welding.
I wouldn't want to meet anyone on the road frantically turning the steering wheel while their car has a steady course for me. :)
Just as a precaution, this product may be good still..
04 Feb 2020 12:12 #218040 by Jefferies
yakuza wrote: I do not recommend anyone to try this "at home". Even if it is cast steel or wrought steel be very careful to use the correct heat treatment both before and after welding.
Agreed, i'd never attempt to weld a component like this, or even be particularly happy with a welded one full stop.
04 Feb 2020 14:38 #218043 by RainerK
Replied by RainerK on topic Jimny drop pitman arm
If you have a qualified welder with a proper WPS welding is no problem, also for critical parts.
All the power plants including the nuclear ones are welded, of course with preheating and post weld heat treatment, proper filler, and also testing afterwards.
So this can be done properly, but definitely not just by a usual garage.
  • g r e e n
  • Visitor
  • Visitor
04 Feb 2020 15:22 #218044 by g r e e n
Replied by g r e e n on topic Jimny drop pitman arm
I suggest my variant. I took a bigger steering rod end from MMC Pajero and redrill knuckle hole from top to bottom. This way lifts up the knuckle end to 6 cm.
I did this because I made front radius arms over the axle.
Time to create page: 0.147 seconds
Powered by Kunena Forum
