BigJimnyMeet 2024
Re:GEN 4 Wobble
- Thank you received: 5
07 Oct 2019 20:29 #214441
by Micheal
GEN 4 Wobble was created by Micheal
My SZ4 has quite a marked wobble coming from the front wheels/axle area and felt strongly through the steering wheel at speeds around 40mph. Is this something others experience, it has only done 2900miles. It feels like the wheels are out of alignment or unbalanced. Grateful for any other opinions and sorry if this replicates any other thread.
- Thank you received: 478
07 Oct 2019 20:33 #214442
Replied by Soeley on topic GEN 4 Wobble
No wobble on mine.
Has it always done it or just started? If so have you changed anything?
- Thank you received: 320
07 Oct 2019 20:51 #214443
by Gadget
Replied by Gadget on topic GEN 4 Wobble
No wobble here either at close to 5000 miles.
- grumyoldjoe
- Elite Member
- Thank you received: 20
07 Oct 2019 21:09 #214444
by grumyoldjoe
Wine improves with age.
Replied by grumyoldjoe on topic GEN 4 Wobble
Have you checked the obvious first.?
Wheel nuts all tight ?
Tyre pressures ok ?
Jack it up and try each wheel for sideways and top bottom free play
Any oils coming from knuckles ?
Tyre pressures ok ?
07 Oct 2019 21:11 #214445
by Micheal
Replied by Micheal on topic GEN 4 Wobble
Thanks all, will check all the obvious things tomorrow, was dark when I got back.
- grumyoldjoe
- Elite Member
07 Oct 2019 21:14 - 08 Oct 2019 04:01 #214446
by grumyoldjoe
Also take it back to dealer, dont mess with it and void your warranty
Last edit: 08 Oct 2019 04:01 by Lambert. Reason: Swearing. Please remember this is a family friendly forum.
- Tex
- Visitor
08 Oct 2019 09:33 #214461
by Tex
Replied by Tex on topic GEN 4 Wobble
No wobble on mine either. Nearly 4000km done.
09 Oct 2019 09:58 #214505
by Micheal
Morning Folks, had a look at the obvious points this morning, nothing I could see that would account for the wobble. We bought this second hand with 1000 miles and the previous owner had changed the wheels from 195/80R 15 to 215/75 R15 and fitted Grabber AT tyres. Could this be the reason?
Thanks
Thanks
09 Oct 2019 11:03 - 09 Oct 2019 11:04 #214509
Replied by mlines on topic Re:GEN 4 Wobble
Are they fitted and balanced correctly? In particular look where the yellow and red dots are on the tyre in relation to the rim.
If there is a yellow spot this should be next to the valve.
If there is a red dot (and a yellow one) the red dot should align with the dimple or dot on the rim and the yellow dot ignored
And definitely check the pressures
Last edit: 09 Oct 2019 11:04 by mlines.
- Thank you received: 95
10 Oct 2019 22:26 #214587
by Bob1050
Replied by Bob1050 on topic Re:GEN 4 Wobble
Have passed 10k miles (not kms) and zero sign of any death wobble on mine. As others have indicated - it may be down to other issues such as tyres/wheels.Certainly shouldn't be down to wear and tear on the axle/steering components at such a low mileage.
13 Oct 2019 07:29 #214685
by kirkynut
Replied by kirkynut on topic Re:GEN 4 Wobble
I reckon it is wheel balancing.
13 Oct 2019 09:43 #214691
by Micheal
Replied by Micheal on topic Re:GEN 4 Wobble
Thanks all, the tyres were a bit low on pressure and that seems to have improved it a bit (I might just be getting used to it!) but I still detect a wobble esp around 40mph. I can't see anything obviously wrong, will take it in to have wheel balancing checked.
Time to create page: 0.203 seconds
