Mono bloc calipers
- Thank you received: 1755
Question. Has anyone found a compatible multi piston caliper that doesn't have any slides that could be used ideally with the existing or slightly modified mounting system and possibly the diesel ventilated rotors? Not talking big brakes and Porsche calipers just something a bit more reliable and simple.
Thanks in advance.
- Thank you received: 305
- Thank you received: 650
Yes i think Keithy was involved in this tooRiccy wrote: James Priestly has been fiddling with golf calipers on the grey pickup he has I believe
So you know it's going to be impressive
They're the same as SJ calipers and I never had issues or have ever heard of issues with them. So I can see why you want them but there's no need. I've been through the same thought processes.
I drew up a bracket so that Golf 2.0TD calipers could be used...cheaper to buy new calipers than pry some early vit calipers from someone......and they usually require a rebuild anyhoo.
Essential for spirited driving and 200hp+ Jimny's
Lambert wrote: And they then run the ventilated diesel front disc?
Exactly.....new genuine ebay calipers and a pair of vents....done.
